Question about Intellinet Active Networking Internet Router With 4 Port Switch
I have a belkin wireless router and I purchased a apple ipod touuh and to access wi-fi they tell me i need a pass word from belkin can you help me it is model f5d7234-4 v4
What's your problem?my ipod is asking for password to connect to wi-fi, what is my password? How do I find out what my password is?
Go to the Belkin setup page (http://192.168.2.1/index.asp) and select Wireless 1) Wi-Fi Protected Setup(WPS)
Select
2) Push Button Configuration (PBC) Method Push and hold PBC button on your Router for 3 seconds or click "Start PBC". Then start PBC on the device you want to connect to the Router within 2 minutes.
Oct 01, 2011 | Belkin Basic Wireless Router
Tip
How do I Connect my iPod Touch to a Netgear WNR2000 Router
<p>Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network. <br /> <p><br /> <p>1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start. <br /> <p><br /> <p>2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range. <br /> <p><br /> <p>3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top. <br /> <p><br /> <p>4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range. <br />
on Aug 05, 2011 | Apple iPod touch
How can i have an internet connection with my itouch gadget thru belkin router? thank you.
  • Touch the "Settings" icon on the home screen of the iPod touch.
  • Choose the Wi-Fi setting and turn it on. You may need to wait a moment while the device locates available networks.
  • Select the wireless network you want to connect to (Belkin something). You may have more than one option based on your location. If you are prompted for a password, enter it and touch "Join."
  • Opt to have your iPod alert you when there is a new network you can join. This can be useful if you are no longer in range of a network you have previously used. To receive these messages, turn on the "Ask to Join Networks" feature.
  • Tell the iPod touch to "forget" a wireless network that you no longer want to use, so it will not automatically try to connect you. Under the Wi-Fi settings, tap the ">" button next to the network you want to delete and then touch "Forget this network."
  • Expect that some wireless networks detected by your iPod touch will ask you to sign up for a fee-based service. If this is acceptable to you, open up the Safari application from the home screen. You will be taken to a website that explains the terms of service and accepts credit card payments for wireless Internet access.
  • Mar 03, 2011 | Belkin Basic Wireless Router
    I recently purchased a new 4th generation ipod and here's the problem when trying to add apps to my ipod thru my home wi-fi nothing happens [ I had Cox Cable set up my wi-fi ] but when I'm at a Starbucks...
    Go into the setting on the ipod and reset network setting, Restart the ipod and then go back into the network setting and when it ask for the password, Enter the password for your home network
    Dec 23, 2010 | Computers & Internet
    I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
    Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
    • Move closer to the Wi-Fi router or hotspot.
    • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
    • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
      • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
    After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
    • Check for any sources of potential interference.
    • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
    If you are unable to access the Internet while connected
    • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
    • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
    • Verify that the Wi-Fi network settings are correct:
      • Tap Settings > Wi-Fi.
    • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
    • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
    • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
    • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
    If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
    • Restart the device
      • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
    • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
    • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
    Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
    • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
    • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
    • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
    • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
    • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
    Mar 22, 2010 | Linksys Wireless-G WRT54G Router
    I have just bought the belkin wireless g+ mimo and my wireless printer and my son's wii do not recognse it. It comes up with the name we then enter the pass key and it just doesn't work? any help please?...
    the printer and Wii may not recognise WPA security type. change the security type to 64bit WEP. in ur router u'll have WPS(wi fi protected set up) , u need to disable it. this will make ur printer and Wii work.
    Dec 27, 2009 | Belkin Wireless-G Plus MIMO Router with...
    Forgot my password and trying to connect my ipod is asking for password
    access your router with flowing link
    http://192.168.2.1
    then type user name "admin" and password as "admin" or blank or "password"
    then go to wi fi security then find wep or WAP key it is your password to connect your wi fi network.
    Thanks for using fixya.
    Please rate solution if it helps.
    Jul 17, 2009 | Belkin (F5D9230-4) Wireless Router...
    Need to know how to reset password so neighbors can"t access my internet
    http://192.168.15.1
    this is defaults link for acces belkin router
    then go to wi fi security then u see encrption security then u can reset pasword easily.
    May 07, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Cannot get ipod touch to connect to wireless network
    Many Wi-Fi issues can be resolved by doing the following:
    Basic troubleshooting
    • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
    • Verify that you are in range of your Wi-Fi router or base station.
    • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
    • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
    Jan 01, 2009 | Linksys Wireless-G WRT54G Router
    Wi-Fi
    You will not believe me but I have a similar problem. I have also Belkin router at home and wireless connection with my e800 works perfect. A few days ago I have tried to connect my PDA to wireless router of my best friend. His wireless network is protected like mine and after configuration of all settings I had no success. The funny thing is that PDA show me the status CONNECTED but I can not use the internet explorer. Like I said, at home with my Belkin it works properly. I can really not explain what the problem is.
    Sep 08, 2005 | Toshiba e740 Pocket PC
    Intellinet Active Networking Internet Router With 4 Port Switch Logo
    73 people viewed this question
    Top Intellinet Active Networking Computers & Internet Experts
    Terry
    Prashant M
    Prashant M
    Tech support
    Tech support
    Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
