Question about Kenmore 63942 Dryer
Have estate eletric dryer no heat
Tumbles but no heat. had the element checked its fine
  • 32 Answers
Replace both fuses in you fuse panel there are two 30amp fuses you must have 230volts to the dryer outlet.
Posted on Dec 18, 2007
How to assemble belt
Hello Denise, I have seen this problem many times. The sneakers by themselves in the dryer cause a shock effect , when the weight of the sneakers tumbling onto the drum overloads the skinny belt and the belt breaks every time. Usually. if you dry the sneakers along with other clothes or towels this will not happen.
Feb 27, 2014 | Estate TEDS840JQ Electric Dryer
Estate electric dryer not heating. Runs and tumbles fine but no heat. Model number teds840pq0. Took off vent pipe. No clog just cold air coming out. Any advice is appreciated
If you know how, unplug the dryer and ohm out the electric heating element to see if it's broken. you may even be able to see the break in the element with your eyes. If the element is indeed broken, you can order a "restring kit" to replace it- usually very simple to do and only about 1/2 hour to do. If the element is good, check the safety fusable link and the thermal overheat safety switch, if any are bad, they are all VERY easy to replace. Beyond that, things get a little more complicated for a weekend warrior- not impossible, just more involved... Go to the library and check out Orthos "Homeowners Repair Manual"- one of the best written weekend warrior guides out there! Should be able to walk you thru more than you ever thought you could do- I give one to every new friend for Christmas every year... Hope this helps! :)
Apr 12, 2013 | Dryers
Dryer tumbles but does not put out heat
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore 62602 Electric Dryer
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
Will not heat
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 13, 2010 | Estate EED4300TQ Electric Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryer runs continously and does not heat all the time
Heating element
Thermal fuse
Wiring
Aug 22, 2008 | Estate EED4300SQ Dryer
Estate gas dryer
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | Estate TGDS840JQ Gas Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
