Question about Freezers
Where is the defrost timer located Frigidaire FRS26wgh?
  • 4,070 Answers
How to fix a bad defrost control timer frigidaire ffu14fk1cw
Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Ffu20f9gw3
If your unit has a defrost timer, and you don't see it at one of the back corners, then it will be hidden behind the front kick plate either on the left or right corners.
Sep 19, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
The freezer stopped freezing... the temp now reads 40deg (and climbing) and the fridge reads 45deg. I'm mopping up puddles on the floor.
It is possible the refrigerator has gone into defrost and stuck there. I'm not sure what features to tell you to look for but you probably have a defrost timer or something called Adaptive Defrost Control board. They are the part that most likely causes the problem. If you could send me the model number found on the door frame on most refrigerators I would help you locate the parts.. Anyway when they stop cooling like that it reminds me of a defrost timer caught in the defrost cycle and the only way to locate it and turn it clockwise may get you going until the defrost timer can be replaced. I have seen thermostats do the same thing. Thanks Sea Breeze
Aug 17, 2009 | Frigidaire Freezers
Need to force into auto defrost, How do I do
Most of these defrost timers are located on the bottom left rear of the freezer near the compressor.
Slowly turn it clockwise until it clicks off.
Apr 07, 2009 | Frigidaire Freezers
Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle. If you have to do it again, you should have the timer checked, or just replace it.
Jan 02, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
225 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
