Question about Vizio L37 Television
The red light on my vizio 37 remote stays on fluttering
3 Suggested Answers
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
SOURCE: i've got a 37
I am having the same issue, I think the best solution is to replace the inverter slave and master boards. These are the circuits that controls the backlight and causes the flickering when they are malfuctioning.
Posted on Dec 29, 2009
Can NOT change channel on TV with the Plus or Minus or with remote, VIZIO 37
Check the remote control for its infra-red emission; pressing all the buttons on it. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Oct 30, 2014 | Vizio L37 Television
VO37LHDTV10A 37 in Remote malfunctioning
Cheapest route is to get a universal remote and start over. Most remotes have their life span. Sometimes shorter. Any abuse of the remote by dropping, getting wet, etc will make it quit. Hazards of a little piece of equipment we don't see as important UNTIL it does not work!
Mar 06, 2014 | Vizio VO37LHDTV10A 37 in. LCD TV
Reprogram the URC-9910 universal remote for VIZIO E3D420VX
Universal remote code to check with Vizio TV is [0081.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
Dec 30, 2012 | One For All URC-9910 LCD Remote Control
Red lights stays on remote control
If the light on the remote stays on you have a short that will quickly drain the batteries---is issue with the remote light or the one on the set?
Jun 10, 2012 | Vizio L32 32 in. LCD HDTV
37 in vizio tv stays on vizio screen
Main system memory IC might have been damaged. Set need service Contact any experienced service technician; or the authorised service center for Vizio at your town.
May 12, 2012 | Vizio E370VL 37 in. LCD HDTV
Vizio e370vl turns on then powers off
This unit has infra red detector for remote. You may be getting IR from another source in the room (eg: bad light bulb or light reflecting off window pane). Also if you use the JAG Wheel on side of set, instead try the remote - the JAG Wheel may be the problem (dirty switch or damaged).
Oct 04, 2011 | Vizio E370VL 37 in. LCD HDTV
Lost my remote for my vizio 37 inch tv
buy a replacement remote find code in code book with tv u have with remote and manuel.
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
I've got a 37" LCD made by Vizio. After about twenty min. the screen start to flutter or flicker like a strobe light. Power on the unit stays on while this occures. What cani do to fix this?
Dec 15, 2009 | Vizio L37 Television
Vizio L37 Television Logo
434 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
