Question about Belkin F5D8631-4 Router (F5D8631au4A)
I have a F5D8631-4 Router which works extremely well for the 3 computers in the house. I cant seem to connect my new iphone to the network. It keeps coming up with unable to join network. Ant ideas? Cliff
    Problem Solver:
  • 10 Answers
1.Login to any one of your computers
2.Open the router page
3.Change the Channel - 11 and SSID should not have space
4.Set sec for WEP or WPA auth as TKIP
5.Disable the WPS
6.In the Iphone forget all the old networks and restart the Iphone scan for WIFi and connect ...
Posted on Aug 26, 2010
Installing airport extreme card imac g4
Turn off your security because 10.5 with wifi doesn't play nice with router passwords.
Sep 03, 2013 | Computers & Internet
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work...
    To clear out the problem if Network Magic has something to do with your connection.
    1) Uninstall Network Magic from host computer.
    2) Remove Ethernet connections to router.
    3) Reset the router (press & hold reset button for at least 15 secs.)
    4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
    5) Setup wizard prompts on installing Network Magic, just ignore it.
    6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
    Resetting router clears all settings made by Network Magic application made on the router.
    Hope this helps.
    Mar 13, 2010 | Linksys Wireless-G WRT54G Router
    Iphone doesn't work with router Dell 1184 broadband router in my house works with windows laptops but not Apple iPhone or iTouch. I have had the router/software installed for 5 years, is there new software...
    you said the laptop is connected to the network.
    when you try to connect to the wireless network on the i-touch or i-phone, do you see your network.
    if your network is secured then you must enter the correct password for the wireless. If you are not sure about the wireless key or the password then you will need to open the router set up page and check the wireless settings.
    you can also try to upgrade the firmware ( software) of the router.
    Click Here to know more about router and network
    Jan 10, 2010 | Dell TrueMobile 1184 Wireless Broadband...
    Flashing wifi symbol on netgear wireless router. iphone help
    Hi
    I will try to help you out with this....
    Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
    you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
    Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
    open the internet explorer on your wired computer
    type in 192.168.1.1or you can type http://routerlogin.com
    , it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
    click on the wireless settings under the heading of setup
    check out another screen shot below :
    a. Change Name SSID : name of your network that you want to have
    b. CHANNEL : Change to 11 and if uts 11 change it to 06
    c. Mode : change to G&b
    d. Sceurity : Select WEP
    e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
    you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
    connect with it and you are ready to go with your wired and wireless connection
    I hope above mention will resolve your concern.....
    Thanks
    Harmeet :)
    Sep 27, 2009 | NetGear RangeMax WPN824 Router
    I just installed the Dlink wbr-1310 wireless router on my computer. I have a dell dimension desktop that is hard-wired (cat5 or 6 cable) directly into the router's #1 port. Previously, the broadband...
    Get rid of AOL network magic. I'm not familiar with either but I do know it's designed to help people who have no idea how to setup a home network. Log on to the routers cofiguration page and look at the router status to determine what the issue is. i.e is the router dropping the internet connection or is the router not connecting properly to your computers? If your using static IP addresses then you will need to re-configure these for the new router. Start by switching back to dynamic IP on all devices connecting to the router. It may always be a firmware issue with the router. If these steps don't work try updating the firmware (there should be an option in the config page (192.168.1.1)
    Jul 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    Secondary computer will not connect wirelessly; IP address problems.
    If the router is not assigning an IP then you are probably not actually connecting to the network. Try disabling your wireless security on the router and see if they connect. If they do then you know the problem lies in that direction.
    May 31, 2009 | Linksys WRT350N Wireless Router
    I am setting up my 3rd computer on my wireless network, i have had it all running well at another house with 3 computers. i have the main one with the modem set up and working and right now i am on my...
    if was working at another house, your settings are most likely correct. try checking the distance of your computer to the router. you may move the antenna or try changing the channel on your router.
    Nov 09, 2008 | Computers & Internet
    IPhone Wi-Fi only works when it's really close to my home's router...
    Sounds like there is a problem with the WiFi card in your phone, take it back to an Apple store, all Apple stores have a WiFi open network so you can show a Mac Specialist the problem, my thinking is if it doesn't connect at home then it wont connect to there network. If your phone doesn't work in the store ask to speak to the manager or assistant manager, be persistent and insistent if your iPhone is not hacked they will change it but you have to fight your corner.
    May 07, 2008 | Apple iPhone Smartphone
    Open Questions:
    Belkin F5D8631-4 Router (F5D8631au4A) Logo
    238 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
