Question about Garden
My pw0701210.01 started for a few seconds then shut off. It won't turn on again. Any suggestions? Cheers, Richard
4 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: I have a Goodman GMPN120-5
This could be a bad motor, you know those things do happens! It will run till it gets hot and tripps out on internal overload , which reset whens its cools down.!
Posted on Aug 23, 2008
Kuwagata
  • 181 Answers
SOURCE: I turn the tv on and after a few seconds it shuts
Possibly the main Power Regulator is damaged!!!
Open the case, then look for anything that burned out, replace it!!!
If still won't start, you need a multimeter, soldering iron, try locate output diode on power regulator board, then measure the voltages, it has 3-4 type of voltages;
first diode it should around 115V-130 V DC.
Second diode it should around 24 V DC.
Third diode it should around 11-16 V DC.
Fourth ( if exist), check diode and should around 5 V DC.
The problems usually start on second diode, if persist, follow the circuit board.
Posted on Oct 18, 2009
#1 Taper
  • 1041 Answers
SOURCE: I have a tb415c. Has
Here is my Tip(s) on this problem:http://www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Jim
Posted on Aug 14, 2011
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
My Acer Veriton X480 turns off after few seconds and won't boot.
Have you cleaned it lately? Is it getting sufficent air flow? A few cans of compressed air and a can of Electronic Contact Cleaner spray. If so, I would suggest the PSU may be bad. Reseat the memory mods, Try to reboot. If it starts, LED's blink, then completely powers off, Test the PSU with a multimeter, replace if necessary. Do you get anything on the monitor? Or does it shut down before? Had you done any hardware or software updates/upgrades?
Jan 10, 2013 | Acer Veriton X480G 320GB PSV9703004 PC...
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Engine starts fine, runs fine for about 5-10 minutes of various speeds. Then it shuts down suddenly regardless what trottle possision. Engine will start right away again, but promblem will accure after few...
Could be so many things, I know on modern Harleys there is a shut off relay that turns off the engine if the bike is on its side. If that switch goes out, the motor won't run. Probably have to take it to the dealer.
Jul 08, 2011 | Honda Fusion Motorcycles
Won't start ~ rode a few hours then parked it ~ turned on key no lights came on ~ i checked the starter connections ~ all fine there nothing ~ ran great before
there is a high possibility the battery is dead. or maybe the bike isnot charging the battery. i suggest push starting it then ride it a few blocks and shut it off pull the key and then start it again...it might be the attery wont hold a charge...if thats the case then replace it but do that before messing with the stator. hope this helps good luck!
Jun 03, 2011 | 2006 Honda VTX 1300 S
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
2000 gmc jimmy shut off while driving, replaced fuel pump relay, did not help. checked fuel pump and filter, both seem okay. after disconnecting and reconnecting fuel filter, vehicle started and ran very...
Replace the fuel filter first. When you turn the key on, the fuel pump should run for a few moments, then turn off. If it keeps running, then replace the pump as well. Suggest having the fuel system pressure checked at the engine itself. Hope this helps!
Sep 29, 2010 | 2000 GMC Jimmy
I turn the tv on and after a few seconds it shuts itself back off again. At that point I can't turn it back on until I unplug it and plug it back in. However, when I turn it back on it will again turn...
Oct 18, 2009 | Sharp 27K-S100 TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
