Question about Garden
The lawn mower ran out of gas and now won't restart. I tried starter fluid. will spark but not continue to run. Acts like it's not getting gas. Troy built super bronco. 3 months old
  • 80 Answers
Remove plug or plugs and check them to see if tractor is now flooded. Clean plugs and check gap and reinstall. Check carb diaphram to see if it is totally closed or not. This will cause the motor to flood. Good Luck!
John
Posted on Sep 28, 2009
Lawn mower won't start
likely the old gas is gunked up
remove the screw on the bowl bottom an look for a tiny hole thats plugged going across the bottom of screw.
if no screw an bowl then its just gunked up lines.
May 03, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Sears troubleshooting
I think you mean it wont run after running out of gas. You may have to remove the spark plug and shoot a small shot of starting fluid in the hole and replace the plug. Cranking means turning the engine with the starter motor.
Aug 15, 2014 | Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
It will not start. I tried squirting starter fluid in the carburetor by taking off the air filter. I t would then start for a few seconds until the starter fluid was gone. I did that several times to see...
Hello rino.... Make sure you have fresh fuel in the tank, a new spark plug, and a new air filter. Then get that can of starter fluid and a helper. Have the helper continue to squirt a little starter fluid into the air intake after you have removed the air filter. Keep spraying until the engine runs for a couple of minutes and takes off on it's own.
IF after a few minutes of doing this drill with the starter fluid it still won't run on it's own you then have no choice but to disassemble the carb. and clean it. Joe
Thanks for choosing Fixya!
Mar 16, 2011 | Troy Garden
Troy built mower has gas and spark with new plug will not start ,it does not even cough or sound like it is going to start,ran perfect when last ran.
take off the air filter cover and shoot a little gas into the carb.
if it sputters you probably need to have the carb cleaned.
Oct 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Apr 17, 2010 | Garden
! have a Troy built mower with a Honda engine, it quit running and will not start. I changed the spark plug, it ran for about one hour. Now the mower will not start.
Hello. If the gas has been sitting all winter, remove it with a siphoning bulb and put in brand new gas, not even gas that you have been storing all winter. Also, change your air filter. Finally get a can of starter fluid and a helper. While one person squirts a bit of starter fluid into the air intake [near the air filter] the other person starts it and use more squirts of starter fluid to keep it running. Joe
Apr 09, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Mower want start
First, pull the spark plug and see if it is wet/damp with gasoline. That's one way to tell if it is getting gas. Try starting the engine with starting fluid. If it will run with starting fluid, but not on it's own, it is a pretty good bet that there is a fuel delivery or ignition problem. Sorry for your trouble and I hope this helped. Best wishes.
Sep 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
495 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
