Printer is paused and can not be enabled toprint...also does not appear to be connected
Printer is paused in 12 documents, What should I try?
Posted on Feb 06, 2010
Why is my printer offline
Try it...
Double check the connections and also check status from device manager.
Go to Control Panel
printer and Faxes and right click your printer and just click set to online
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Brother MFC-465CN InkJet Printer
Mfc 7340 pause
when we pause some prints from specific computer (if ur using lan) then go to computer where physically printer attached then print some pages and when printer utility display appears on screen find on that pause is enable trying to resume from that
May 04, 2012 | Office Equipment & Supplies
When i want to print to hp color 4730mfp but i'm prompted printer is paused and i click to enable it but it keeps on going back to paused mode
Remove and re-insert the cable connected to the touch screen and also try to calibrate the touch screen. The panel can be removed with ease. If not the touch panel needs to be replaced.
DO NOT FORGET TO RATE THE SOLUTION
Jun 27, 2011 | HP LaserJet 4730mfp All-In-One Printer
The printer is paused and reports a communication error. How to correct this?
Try this following solutions:
  • Turn off your printer then disconnect its usb connected to the pc then restart your printer. If nothing happens connect the usb into a different usb port of you pc.
  • Check if your printer is enabled into your PC. Click on Start then click on Printers. A window would appear and it should show your printer with a check mark, if not right click on it then choose enable.
Hope this solves your problem. Good day.
Jun 24, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My dell p703w printer is not printing black even though i cleaned printer head and reset setting tried several new cartridges what do i do now
Printer Problems Ensure that the printer power cable is firmly connected to the printer and the electrical outlet.
Determine if the printer has been held or paused.
  1. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows Vista®:
  1. Click windoa14.jpg ® Control Panel.
  2. Click Hardware and Sound.
  3. Click Printers.
  1. Right-click the printer icon.
  2. Ensure that Pause Printing is not selected. If Pause Printing is selected, click Resume Printing.
Ensure that you installed the ink cartridges correctly and removed the orange caps from each cartridge.
For more information, see Replacing Ink Cartridges.
Ensure that you loaded the paper correctly.
For more information, see Loading Paper.
Ensure that the printer is not connected to a PictBridge-enabled camera.
For more information, see Printing Photos From a PictBridge-Enabled Camera.
for more detail see this page
http://support.dell.com/support/edocs/systems/p703w/en/UG/troubles.htm
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Dell P703w Printer
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
My printer won't print because i have a job that has been deleted and it says that the job is deleting .... other jobs are listed toprint but won't print?
you have to restart your computer and printer and then make sure the lexmark productivity studio icon is on your task bar and retry to print
Apr 25, 2009 | Lexmark Z611 InkJet Photo Printer
I have a z4mplus and i have no know how to get it toprint bar codes, it prints text but no bar codes
You are using a label design software? Label Matrix or Bartender software, are best.
Feb 23, 2009 | Zebra Z4Mplus Label Printer
Sharing a Kodak 5100 All-In-One Printer
try this.............
On the computer that is connected to the printer:
  1. Open the Control Panel.
  2. Select Printers and Faxes.
  3. Right-click the KODAK All-in-One Printer, and select Properties.
  4. Select the Sharing tab.
  5. Select Share this printer.
  6. In the Share name field, type a name for your printer.
  7. Click OK.
  8. Right-click My Computer and select Properties.
  9. Select the Computer Name tab.
  10. On a piece of paper, write down the full computer name as it appears on the screen (for example: Johns Computer).
    NOTE: This is the name that you enter on the other computer(s) to access this printer.
On the other computer(s):
  1. Select Start > Run.
  2. Type two backslashes (\\) and the full computer name as it appeared on the first computer (for example: \\Johns Computer).
  3. Click OK.
    A window shows the new printer as the Shared Printer.
  4. Double-click the printer.
  5. Close all windows, then print to the Shared Printer.
Let me know if this helped.........
Dec 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
501 people viewed this question
k24674
