Question about Maytag Dependable Care LAT9706
I have a Maytag LAT9734AAE washer that quit after it filled with water I tried to move the knob to the next stage of the cycle and nothing happened. When I turn the knob to the off the light goes off.
SOURCE: Maytag LAT9235AAE fills with water....
I had the same problem. and I did the suggestion dated 9/26/06. Too another piece of hose and attached it to the water level switch and blew into it. and the machine began aggitating. My question is... DO I replace the hose?? or switch?? Now that I have purchased a new machine. I find a solution, Oh well. thanks df
Posted on Mar 03, 2007
  • 209 Answers
SOURCE: Washer water overflow.
i am a recently retired engineer of 20 years and this sounds like a blockage to start with, when you remove the lid you will find a round disc like object (pressure switch) with a thin pipe coming from it going down to the bottom end of the machine, this pipe as either come off or is blocked somewhere. drain the machine totally, clear out the pipes, make sure there are no damaged parts to the pipes, then make sure all are fitted properly, start the machine off again and watch for water level shutting off near the bottom of the door, start with the above, if this doesn't cover the fault there may be an issue with the timer or electrical fault elsewhere/? hope this helps, if so rate me please, thank you
Posted on Sep 13, 2007
AT702
SOURCE: Maytag lse7806ace
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.b88b41c.jpg8de8e68.jpg798b349.jpg49eb6d1.jpg6f06d50.jpg48c84c4.jpg
Posted on Feb 01, 2008
SOURCE: Maytag Washing Machine Problem
MY MAYTAG WASHER HAS STARTED TO LEAK I JUST WANT TO KNOW IF I SHOULD REPLACE THE CENTER SEAL AND TUB SEAL
Posted on Jun 26, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
Washer worked fine all week. Today. I went to use it and I pulled the knob out to start the machine and nothing happened. Just the little red light came on. It is a Maytag top loading model LAT9734AAE
door switch look where lid closes and depresses closed swich that swich has 2 wires on it un plugg them tape them together hit start it should work
Jan 24, 2011 | Maytag Washing Machines
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
My Maytag Washer Model A606 just quit working. No
The small fuse will prevent water from filling if it is blown. .3 amp
Jun 10, 2009 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Hum's when I pull the knob out but nothing happens
I would check the pump for something small that is jamming it sometimes.
Apr 25, 2009 | Maytag LAT3600A Top Load Washer
Maytag atlantis Top loading washer
it sounds like a bad lid switch.
Apr 07, 2009 | Maytag Washing Machines
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
