Laptop Lid will not open
I have a HP Pavillion DV2125 Laptop and the lid is stuck on the top left where the security cable lock is located. It is cracking from trying to open it. How can I get it unstuck ?
  • 192 Answers
There are two metal hinges that are on that laptop model and are at top of laptop near keyboard and screen joint. When one of these hinges breaks, and they do, it can become jammed. By continuing to try and open it you run the risk of damaging the LCD on the laptop. The top of the laptop has to be removed to access the hinges and replace them. This is not something a novice can do easily and is dangerous to the laptop. If its not under warranty and you feel comfortable with your skills you can try. However I would recommend a repair shop. The hinges for this model run about 10 dollars for the pair and the labor would be whatever the local rate is. To see the hinges that are for your unit.. this link has a good picture http://battery-adapter.com/product_info.php/products_id/3463
Posted on Jun 03, 2010
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MFC8860DN SAY'S SCANNER LOCKED?? WHAT'S THE FIX??
Hello my friend.If you open the scanners door under the document cover is one switch that locks and unlocks the scanner.Move it to the position that shows that is unlocked.If this doesnt work it means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This should fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remove the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable . After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp more into the scanning area and repeat until works.
Feb 09, 2010 | Brother MFC-8860DN Printer
Reads "OP" when lid is closed
Magnetic reed switch on left side below the gray rubber bumper, shown here...
http://www.repairclinic.com/SSPartDetail.aspx?PartID=1033130&PPStack=1
Release two spring clips in front between main top and front panel using putty knife. Lift the main top and access the left and right door locks here.
To access and see if the magnet is in place, remove the dispenser from lid.
Gently pry the bottom of the plastic inner lid toward you then down. This will let you see if the magnet is in place on the right front corner of the inner lid.
http://fixitnow.com/wp-content/uploads/2006/09/washer_switch.JPG
Seems to be a common problem with this washer. Apparently, the lid isn’t completely watertight and allows water to get into this switch corroding the contacts and the wires.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 09, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Have the OP signal, have cleaned all latches and lid areas but still not working. how do i pop off the top portion to check the side locking latches? i can see they are not well sealed and would rather fix...
This is a common problem on this washer. (The OP fault code). It is caused by a faulty magnetic reed switch. Apparently, the lid on these washers isn't completely watertight and allows water/moisture to get into the switch and corrode the wires and connections.
The switch is on the left side under the rubber bumper, Release two spring clips in the front between main top and front panel using a putty knife. Lift the top. To access and see if the magnet is in place, remove the dispenser from lid. Gently pry the bottom of the plastic inner lid toward you and down. This will let you see if the magnet is in place on the right front corner of the inner lid. Here is a picture of a bad door lock switch:
Sure hope this helped and best wishes.
Jul 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error Code showing UC
Hello plthrsn64 ,
You should open up a separate problem for this but I will post as a solution for the Lid Lock Issue.
For the FAV6800AW that is you machine type correct? The "LO" console error is "Lid has failed to unlock". I haven't experienced the "LO" error code to the display but this is the direction I would go in. I feel you have a signaling problem back to the control board in the console from the lid is unlocked contacts in the left/right Lid Locks.. I would disconnect the left and right lid lock plugs to the washer. The right lid lock is not necessary for operation. The left lid lock is the important one because of its dual signaling function, the Lid is closed signaling from the magnetic reed relay and lid magnet and the lid is locked signaling from lid locks slide switch in the lid lock. I think you may corrosion build up in the left lid lock such as the Pic’s I will attach show of other users. The left lid lock is subject to corrosion brought on by the bleach dispenser.
You can start by un-seating the right lid lock and leave off. Then try un-seating and re-seating the left lid lock plug a few times and see if that will get you back in service. Be careful those plugs are difficult to pull out. Please remove power to the washer first then you will need to lift up the washer top to access the lid lock plugs. Here is the process, use the service manual for additional support.
The Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
If seating/reseating the left Lid Lock a few times doesn’t help I would remove the left lid lock per the Service Manual, carefully open up the left lid lock and see if corrosion is the issue. The plastic latchs around the lid lock enclosure can break off very easily be careful when opening the lid lock. If you have severe corrision I would use some WD-40 to clean up the contacts with a Q-Tip. The cntacts for the Lid is locked slide back and forth with the activation of the solenoid in the lid lock. You may have to rock back and forth the solenoid to clean up the slide switch. Just watch how the relay parts sit in the lock the latch arm will come out and you will have to fit back together to operate correctly. Sounds complicated it is not, it's just difficult to explain. If you have to replace the left lid lock here is a link.
Left Lid Lock Double check Part number if you order.
Corrision of Left Lid Lock
Close up of contacts in Left Lid Lock
My normal left lid lock in my machine which was purchase in 7/05.
Mar 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
BROTHER MFC-8840D "Check Scan Lock" error message
I had the same problem. It means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This may fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remover the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable be carefull not to drop the lid, break the cable or the glass bed. After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp farther into the scanning area and repeat. Good Luck
Oct 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
How do you clear a od error code on a maytag fav6800aww
I agree with fastnhonda troubleshooting. I will just toss out some additional info. I’m an owner like you just trying to troubleshoot from a distance. The OD alarm is signaled by the control board when the control board has not seen a lid open signal from the left lid lock for three completed wash cycles. Could be corrosion issues with the left lid lock and or plug connecting to the left lid lock. If you pull the power plug on the machine then re-power up does the “OD” alarm clear? This might clear the “OD” alarm for three wash cycles. If it does can you do this; open the washer lid and start a Spin Only cycle with the lid open do you throw an OP (Lid Is Open) alarm to the console? If so do you clear the “OP” alarm when you close the lid? I’m checking the signaling functionally of the Left Lid Lock assembly of the magnetic reed relay and lid magnet thru the left lid lock and plug back to the control board.
If no results come from above testing and you want to DIY the repair I would remove the left lid lock (remove the left lid lock as shown on page 34 of the SM) and inspect for corrosion issues as the other forum member speaks to and a possible broken wire connection on the magnetic reed relay. See the red & black wire going to magnetic reed relay switch as shown in the pic. below. Note the black wire is broken away from one end of the magnetic reed relay do to corrosion. If you take apart the left lid lock the tabs holding the case halves together break off very easy so be careful on disassembly. I would not replace the right lid lock just yet. Removing the plugs on the lid locks is difficult so be careful. I would remove the left lid lock and inspect and clean up wih WD-40 if there are corrosion issues such as shown below or a broken wire (re-solder) on the magnitic reed relay. If this doesn’t resolve the “OD” alarm I would then replace the left lid lock only at this time. The right lid lock is not needed for normal washer operation.
Support info;
Left Lid Lock always give you pats supplier you machine model number when ordering parts. No machine serial number is required for this part.
Disconnect the washer power cord.
Jul 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Lid Lock Replacement
I have replaced my right lid lock twice and the second one just went bad. The left one does not matter, only the right one tells the washer the lid is locked. I think the bleach cup is the problem, bleach corodes the metal contacts in the lock. Try removing the plug and cleaning the contacts. I am going to bypass this lock I am not buying any more parts for this unit!
People have reported replacing this lock several times in unser two years.
Aug 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
