Question about Canon PIXMA MP470 All-in-One Printer
Where do you put the ink - Canon PIXMA MP470 All-in-One Printer
How do I put ink in for IDEAL300?
  • Push stamp down slightly and push buttons on side to lock into position (Image 1).
  • Push button and then pull out ink pad (Image 2). For other style Trodats, just push the ink pad (there will not be a button).
  • Put 10 - 20 drops of Ideal Ink on the inked side of the pad.
  • Once the ink has absorbed into the pad, push the pad back in (Image 3).
Jan 09, 2012 | IDEAL 300 Custom Rubber Stamp - Black Ink
Put new ink in printer and printer is saying out of ink
It's not recognizing the ink. Try to remove the ink and put it back in and apply a little pressure. If it doesn't work, replace the ink.
Dec 09, 2010 | Epson Stylus CX5000 InkJet Photo Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Put new ink cartridge in Epson NX 110
I have a epson stylus NX110 Printer the ink cartridges will not stop so that i can put in new ones.I press the stop button but the ink cartridges will not stop onthe arrow so that i can put in all new ones.
Apr 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
Cant change ink settings ie puts too much ink on
Don't use glossy paper. I use Mate 10 lbs.
Try that.
Good Luck.
If that works, pls rate me.
Jan 13, 2010 | Epson Stylus R265 InkJet Photo Printer
I put a refilled black ink in my HP PSXçC
the problem with the refilled ink is that the ink is NO WHERE near as good as the original HP ink and the ink cartridge is now damaged - just replace the cartridge with a new HP cartridge and you should be OK!
Dec 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
Put new black cartridge in now no black ink what could be the problem
it could be you waited too long to replace the ink and the nozzles are dry, or the ink cartridge you put in is also low or no ink. try doing a couple ink cleanings and do a test print, see if it helps.
Nov 23, 2009 | Brother MFC-260C All-In-One InkJet Printer
I donot know how to put ink in my printer jnhb55564
first turn on you printer.
second open you cover then you will see the print head cartridge is running out i think he will stop in you left hand side or right hand side.wait for he stop running.
third after stop running plug out ink just press down ink about 45 degree then you can take out ink.remember when you put out ink see number ink before installation.
4.when install ink remember to take out plastic sticker gum inside ink.now install ink jus put in inside by 45 degree the press up him after that is ok
5.close the cover and try to print.i think black ink in left and colour in right i no sure but try .... ok....
Aug 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Refill instructions
Go to shop; buy Epson T0731; open packet; Press the change ink cart button on printer, put new cart in; press change ink cart button again. Wait for whirring to stop. Hey presto.
Feb 07, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Canon PIXMA MP470 All-in-One Printer Logo
14 people viewed this question
old marine
old marine
