Question about Cycling
What's wrong with my new Centaur Ergo levers -
What's wrong with my new Centaur Ergo levers - operating the rear changer is very hit and miss - the ratchets for changing both up and down either slip or won't move at all
    Problem Solver:
  • 5 Answers
Check that the shift cable can move as some time they stick. WD40 spray can free this up.
Posted on Sep 28, 2009
The throttle cable has come loose or broke at the speed lever, I don't know what a good or new cable should look like
These throttle cables are usually held down with a ***** and tab.
If it is loose simply adjust to best fit and tighten. You do not want a lot of flexing as you operate the throttle lever. This could cause the cable to break. Don't worry about what a cable looks like as long as the cable inside slides easily. Some cable lube once in awhile will go a long way to preventing rusty hard to use throttle cables.
These cables are generally used on everything and very common.
Ergo.... inexpensive. Good luck Hope this helps.
Apr 17, 2016 | Garden
My 2013 dyna super glide won't start I installed new levers and chrome housing. The running lights come on when I turn on the ignition switch. But no high beams, no horn, no hazards, And the brake light...
You missed an electrical connection or severed an electrical connection. Go back and investigate where you touched the bike and you might find that dangling electrical ground or connection. Good luck!
Nov 22, 2014 | Motorcycles
How do i replace the split hood on my campag veloce ergolever without risking splitting the new one? Thanks
Search engines provide instant video help if you use them.
"replace hood on my ergo lever"
Jul 09, 2011 | Cycling
Lost operator manual for sony md/cd changer control any where i can gey a new one
I do not see model number of your Sony unit so can give you Sony Support link, put model number of your unit as it would be written on label pasted at rear/ bottom and hit enter to get free copy of required user manual.
Thanks.
Jan 05, 2011 | Sony Car Audio & Video
How do you replace campagnolo 8 speed ergo shifter hoods
You have to remove ergoshift levers and pull off backwards, a good tip putting on new ones is to spray with hairspray, it lubes them going on and helps them stick in position
Mar 08, 2010 | Campagnolo Cycling
How does the break cable go through the shifter?
Go to parktool.com/repair and click the brake levers of the bike to bring up a list of brake-related info. Select brake levers, which is the first on the list. The Campy levers and cable are the second topic in the article. There are pictures.
Nov 19, 2009 | Campagnolo Chorus 10 Speed Short Cage Rear...
CDs will not load
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Nov 08, 2007 | Alpine CHM-S630 6-Disc CD Changer
Disc changer
regards
Mark
Oct 20, 2007 | Alpine CHA-S624 6-Disc CD Changer
Won't Play CDs
regards
Mark
Oct 08, 2007 | Alpine CHM-S620 6-Disc CD Changer
Cycling Logo
112 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
