Question about Creative Labs SBS 370 Computer Speakers
Any replacement for the adapter that broken???
Plugged in not charging
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
http://www.chargerbuy.com/laptop-ac-adapter/hp-ac-adapters.html
Jan 20, 2013 | HEWLETT-PACKARD Computers & Internet
There could be several things wrong. You could have a broken DC jack on your motherboard. To prove this, wiggle the DC jack with the adapter plugged in. If the charging light comes on when you wiggle the jack, then your jack is broken. You could also have a defective AC adapter.
Jan 06, 2013 | Toshiba Satellite C655-S5125
Dell latitude d510 has no power
Please check out the following steps to confirm the real issue:
I think the most likely cause is that your dell charger is broken, just try a new charger to test:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Dec 04, 2012 | Dell Latitude D510 Notebook
My tr3a reboot like every ten minutes when i am using it with the battery?
4. The motherboard could be defective & needs to be replaced.
Sep 10, 2010 | Sony PCG-TR3A Notebook
My Dell D 600 will not charge the battery and a message appears at start up that says Ac adapter not recognized What do I need to do to get my computer to charge the battery
If the AC adapter is not recognized by the system, the battery charger circuit is disabled. Things you can check:
  1. In the barrel of the connection to the computer, the small wire in the center is the sensing wire. If bent or broken, then the adapter will need to be replaced.
  2. If the pin is not bent or broken, try a different AC adapter (Any D-Series Dell adapter will work) IF that adapter works, replace the AC adapter.
  3. If a known good/new adapter doesn't resolve, then a motherboard needs replacement.
Jan 10, 2010 | Dell Latitude D600 Notebook
My ac adapter is broken, can i buy a new one
Yes you can buy a replacement power adapter to any computer of electronic store near you and it will be better if you take the broken adapter with you so they can provide you the correct one....
Nov 14, 2009 | Dell A960 All-In-One InkJet Printer
Acer laptop Aspire 7000 does not power on
If the laptop does not power up (not a slight sign of power flowing through it) even if the AC adapter is plugged into it, here are the possibilities:
1. You AC adapter might be broken and need to be replaced. Some AC adapters have a light on it to signify that there's power flowing from the power outlet to the power cable.
2. If your AC adapter is working fine, maybe your power supply is broken. If your laptop is with in warranty, have Acer replace it. If not, find a repair center who does.
Apr 10, 2009 | Acer Computers & Internet
Charging Adapter
i think your laptop needs 90watt adapter because of that its not charging.....
Jul 24, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
BROKEN ANTENNA BROKEN AC/DC ADAPTER
I just started to put some stuff on ebay and I have new one ac/dc adapter Model # ae9512
Good Luck!
silverrockny (my ID on ebay)
Store nameon ebay: The right Stuff Store
Oct 27, 2007 | Emerson iP100 Clock Radio
Creative Labs SBS 370 Computer Speakers Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
