Question about Samsung HLR5087W 50" Rear Projection HDTV
The Tv will not read the cable card
Tv works but wont read the cable card. I had the card checked and it is good. The technician told me that I need a new cable card board. I went to partsstore.com but I don't know which board I need as they list by part number. Where can I get a schematic for this tv to see how to install?
thanks
Sandy
ctf1800
  • 4402 Answers
SOURCE: Samsung HCN473WX
you may need to do convergence to align the colors up.
the only thing other than the ic that need to be replaced are resisters and if the resisters are bad you would not be able to move one of the colors, and blow out the ic you just installed.
Posted on Jan 28, 2008
ladywinn
  • 5138 Answers
SOURCE: samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Posted on Mar 31, 2008
ladywinn
  • 5138 Answers
SOURCE: Samsung HCP4363WX/XAA
Was wondering if you got set fixed yet? STK-392-180s are the ics I use when repairing convergence.Replace both chips.
  • 195 Answers
SOURCE: samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Posted on Nov 10, 2008
  • 298 Answers
SOURCE: A Samsung Tv model #HLN5065W
Model # HLN5065W Digital Main Assembly Board should be part # BP94-00385A. Here's a link to a major Samsung distributor:
Samsung HLN5065W Replacement Part Digital Main Assembly Board
***There's also a manufaturer's notice: If you replace the digital main board (BP94-00385A) you must replace the main analog board (BP94-00434A) per mfg bulletin# ASC20040728004.***
Samsung HLN5065W Replacement Part Main Analog Board
Posted on Jan 02, 2009
Child lock and the remote wont work on it i tried other tcl remotes and it the same thing the buttons on the tv dont work either when press it says key lock help me out plzz
Can the tv be reset to factory default , if it can this should undo the parental lock.
If not, contact a repairman who has experience of your make. I had a forgotten password on a technomate satellite receiver and the technician told me that the model I had was installed with ageneric code in case the user set code was forgotten.
Anyway, reset if you can and ask a tv technician if you cannot
good luck
Jun 23, 2015 | Televison & Video
My sansui LCD wont come on. I have checked all the cables. I switched it off last night and it was fine
Sounds like the power supply regulator board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 10, 2015 | Sansui Televison & Video
My dynex 19" lcd tv doesn't work when i turn it on and try to set it up all i get is a distorted screen that you cant read i was told that it has to be reprogrammed is there software for a computer to fix...
When you turn it on press the set up/menu button. Make sure your cable is unplugged first. When in set up, go to channel setup and scan channels. Once the scan has started connect your cable back to the tv. Allow some time for the scan to complete. ***I learned this when I emailed a dynex technician. If it does not work after the above, email dynex http://www.dynexproducts.com/contact-us.html
Oct 08, 2014 | Dynex Televison & Video
Wont power on
You need to check the mains (cable and the socket voltage). Check the availability of the main supply either with the voltmeter (if you have) or plug any other thing like table lamp or any electric appliance for conformation of desired voltage. If voltage is there and still TV is not Switching ON then check the cable itself. For this, you check the plug itself. To check the cable you have to remove the cover and then check main fuse too.
(IT REQUIRES TECHNICAL SKILLS)
If you are not a technical person, get it done with some technician near you.
Hope, it will either FIX or help to fix the issue.
good luck
Jan 29, 2010 | Westinghouse LTV-20V2SL 20.1 in. ED-Ready...
My toshiba 62 in.HD tv with cable card did receive the built in TV guide with cable chanel number and a brief description of what the program is about untill May of 2009. Comcast has repetedly told me to...
the tv guide is kind of like a computer application. so the cable box can run that application or function. the cable card is an add on to your digital tuner which allows for the bits/codes to be descrambled. there are so many manufacturers of cable tv converters that it would be nearly impossible for sony or panasonic or toshiba to have an internal operating system to run the guide application. you may have bought a mac but the service is written in windows, for example. unfortunately the technology is simply not there for a cable card to do more than unscramble the digital signal. and inside that cable box from the cable company IS a cable card.....
senior technician
quality control supervisor
telephone installation trainer and supervisor
Field Supervisor
Hey I just work for these guys at Charter, i think they **** too.
Jan 17, 2010 | LG 26LX1D 26 in. LCD HDTV
Acer9303 i have aproblem with the screen.sometimes when you turn on the computer the screen doesnt work and you have to move the lid to make it work.other times if you move the screen it goes white and you...
This is normally a screen cable problem. You must contact a computer technician to check the cable for you. If it needs to be changed, you will be told. Since it works when you move the lid, it should only be a cable problem.
Nov 10, 2008 | Computers & Internet
Dimension 4550 10 100 Network Problem
chk in the device manager if the netwrk card is listed correctly.....also try disconnecting & reconnecting the cables
Jun 23, 2008 | Dell Dimension 4550 PC Desktop
Picture cuts out after three seconds
The problem is your cabling. Plug the cable from the back of the Comast box directly into the TV. Do NOT plug it into your AMP. See the link below for details. http://www.audioholics.com/education/frequently-asked-questions/why-wont-my-cable-box-video-work-with-my-receiver Good luck.
Jun 02, 2007 | Arris DCT6200 DTV Receiver
Samsung HLR5087W 50" Rear Projection HDTV Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
