Question about Toshiba Televison & Video
When I turn on my Toshiba HDTV I get an error message: Lamp life over error.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.This error occurs after the TV crosses 8000 hrs. After this error appears you'll need to replace the lamp and also get the ballast checked.
Please note that replacing the lamp yourself is not recommended, until you are a qualified repair tech or know how to deal with high voltage circuits. Also note that the TV contains very high value of voltages even when it is switched off.
However, if the TV is new or is 2-3 yrs old then it is preferred to reset the TV from service mode. You can enter the service mode by---
Write down the original setting just in case you have to go back.
1. TV turned on
2. Press 'Vol down' button on the set.
3. Press '9' button on the remote and hold. You are now in the Adjustment mode.
4. Use the 'Channel up' or ‘Channel down' to select the item.
5. Write down the old value of the item before changing.
6. Use Volume up and down adjust the value.
7. When you have made all the adjustments you want turn the set off to exit.
Or try this procedure—
1. TV turned on
2. Press 'Mute' button on the remote.
3. Press 'Mute' button on the remote again and hold.
4. Press the 'Menu' button at the TV. You are now in the Adjustment mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 27, 2009
My toshiba model#52hm84 has low light and will not switch high & low light settings
It may be the lamp and be advised---if this set has the quick on feature in the menu it will shorten the life of the lamp.
If there: it does not fully turn lamp off when set is shut down--lamp is lit at about 40 percent!
Dim picture usually is the lamp.
Apr 23, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
The picture won't come on and when I push the power button it says lamp is not working
The tv "LAMP" LED light indication flashes or stay on.Ur tv the projection lamp life are over.Ur tv require a new projection lamp.
Jan 19, 2011 | Toshiba 50HM67 50" HDTV
How does one rid of the "projection lamp is nearing end of life" after an otherwise successful replacement?
Just used the box that came in with the new projection lamp.Take the old projection lamp put it into that box.Put it in the trash recycle bin,that how u get rid of it.
Oct 19, 2010 | Sony KDF-50E2000 50" HDTV
My sony KDF-50E2000 TV has screen message coming up that says projection lamp life is expiring, is the XL2400 the proper replacement and will that correct the problem
Yes XL2400 is correct number. Replace Lamp message is a timed message that will reset and turn off if you unplug TV when lamp is removed and replaced.
Mar 02, 2010 | Sony KDF-50E2000 50" HDTV
I recently replaced the lamp bulb...it worked for a day and now I have sound and no picture and when you turn the tv on I get red flashing lights...and the after they are done flashing the light is blue.
You could have gotten a defective lamp. Try another lamp. Since you have a Toshiba youll be using it even if you don't need it now. Toshibas have short lamp life. If lamp does not fix then the light engine will have to be removed and sent to Toshiba to be rebuilt. They are no longer available.
Nov 18, 2009 | Toshiba 50HM67 50" HDTV
I'm getting a rainbow tint on the upper 1/5th of
usually when the lamp is going out the picture gets dark if you are getting a rainbow tint most likely the light engine is going bad.
Aug 17, 2009 | Toshiba 56HM66 56" Projection HDTV
Resetting lamp hours
No its not correct this error message is telling you your lamp is going out and pruchasing a new one will reset this otherwise you have to cut some wires! i would not recommend that!
May 25, 2009 | LG DU-62SY20D 62" Rear Projection HDTV
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Televison & Video Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
