Question about Whirlpool Duet GHW9150P Front Load Washer
After 5 years and 9 months (just 9 months outside my 5 year warranty) my Duet washer bearings went. $600.00 to repair!! What makes this even more upsetting is, this is known problem. The repairman said 50% of the necessary repairs after 5 years are the bearing. SHAME ON YOU WHIRLPOOL!! Legal action should be taken against you. You have lost a customer. I am letting everyone I know not to buy Whirlpool!!!!
  • Whirlpool Master
  • 8,404 Answers
If you want to repair this, I would suggest you go to RepairClinic.com to look for parts. They are also very good and generous with the advice on how to fix your particular problem.
Posted on Sep 27, 2009
  • 15,935 Answers
Thanks for the information.
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Rattling noise like a marble in drum in whirlpool duet front loader. Only 5 years old.
It is most likely a coin. It has got under one of the paddles and flops up and down. Turn the drum by hand till you find the spot and see if you can fish it out.
Dec 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front load washer has started making noise during its final spin cycle. It has been doing this for about 1 month now. The washer is about 2 years old and has been fine until now. What could my problem...
IF YOU REACH IN THE TUB AND SPIN THE BASKET BY HAND IT SHOULD BE SILENT. IF THERE IS NOISE THIS WOULD BE A TUB BEARING. EXPENSIVE TO REPAIR EVEN THO THE REAR TUB SHELL IS A PART ONLY WARRANTY FOR TEN YEARS MOST OF THE TIME. OVER PROBLEMS CAN BE A STRUT, OR THINGS IN THE PUMP. IF IT IS THE TUB BEARING YOU MAY NOT BE ABLE TO TALK TO SOME ONE IN THE SAME ROOM WHEN IT IS SPINNING. THIS PROBLEM NEEDS ATTENTION SOON. LET ME KNOW IF I CAN FUTHER ASSIST YOU.
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can you tell me the size of my Durt washher, and how long is the rear basket bearing under warrenty? Model# GHW9100LWZ Serial# CSR1819478
Your duet washer size is 3.7 Cu Ft. Bearing last long or short depend on how ofter you use and how much clothes and whether you use heavy or light cycle.
Normal use will last sometime 8 or 10 years.
Heavy use between 5 - 8 years.
Warranty on bearing ??? Not sure
Nov 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet sport front-loading washer that is about 4 years old that is now making a squeaking/ticking or slight scraping sound when the tub turns. Even when I turn the tub when empty I can...
before calling any repair man,
take a flashlight and carefully inspect tthe inner tub
on a few service calls with this particular complaint
ive found small nails, taks, penny nails, screws, what have you that fell into one of the holes and got stuck
barring that , i would get your bearrings checked yes
at four years you should still be inside your part warrenty if it needs to be replaced
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I was told the bearing is shot on the Whirlpool Duet Washer and it is not worth repairing, the machine is only 6 year old, any advice?
a 6 year old washer should not be scrapped unless it is made in china, replacing a 5$ bearing is worth fixing. even if you need to buy a drum unit.
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
how old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help with bearing
i do hope that you have been using he detergent if not it will take the bearing out, if you have then the bearing just went bad i would call whirlpool at 800-874-4698 they may be able to offer assistance if you dont have an extended contract on the washer
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
