Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do I remove the glass to clean both sides
    Scholar:
  • 96 Answers
Look around the perimeter of the glass, there may be some plastic being held down by screws
Posted on Sep 28, 2009
    Scholar:
  • 52 Answers
U can read it here: threre are similiar problem resolved in fixya.com. good luck
http://www.fixya.com/support/t103792-scanner_failure_hp_6110_noise_stuck_head
Posted on Sep 27, 2009
How do I clean the inside glass on my electric fireplace
To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well.
Cleaning Steps
1.Disconnect from Power Supply Before beginning to clean your electric fireplace, turn the heater off and allow to cool completely. Always disconnect the electric fireplace from the power supply before cleaning.
2.Check the Electrical Components Check any wires and plugs to make sure that they are not worn or frayed. This is a rare occurrence, but can become a fire hazard if not addressed. If this happens, consult a professional to repair or replace before using your electric fireplace again.
3.Clean the Heater With a clean, dry cloth, wipe down the surface of the heater. Using the soft brush attachment of a vacuum cleaner, gently clean the heater outlets. This will remove any dust or debris from the heater and keep it running at top performance.
4.Clean Both Sides of the Glass Follow the instructions in your owner's manual for removing the front glass panel. Once removed, you can clean both sides of the glass. Do not use abrasive cleaners, as they will scratch the glass. Dust can be easily removed with a clean, dry cloth. Fingerprints or other marks can be removed with a damp cloth; dry the glass with a lint free cloth to prevent water spots from forming.
5.Dust the Interior Dust may accumulate inside your electric fireplace, like any other unit in your home. To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well. When you are finished, place the front glass panel back onto your fireplace following the instructions in the owner's manual.
6.Remove the Soot Just kidding! You never have to worry about dirty, grimy soot with your electric fireplace. Instead, just relax and enjoy!
Nov 14, 2017 | Miscellaneous
Clean glass door
  1. Clean the area as normal to remove any superficial dirt and dust.
  2. Next, apply the chosen cleaner using a sponge or soft cloth.
  3. Allow it set for a few minutes. (if applicable)
  4. Use the hot water to gently scrub the area and remove the cleaner.
  5. Repeat until it is cleaned completely.
  6. Rinse with clean water.
Mercedes wheels
May 31, 2012 | Stoves Kitchen Ranges
LHow to clean under side of glass plater
note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
Oct 06, 2010 | Canon CanoScan D1230U Flatbed Scanner
I want to clean the underside scanning glass of the HP C4180 scanner/printer because when I scann, the top is clean, but the scaned pictures look like they have little specks of dust all over the scanned...
It takes several steps to remove the glass carrier for cleaning, but it's not really difficult. You'll need a T10 Torx screwdriver, eyeglasses cleaner or similar, and a lint-free microfiber cloth.
1) Remove usb and power cables. Flip the front covers open (revealing the cartridge-insertion area). Remove 2 screws from the right-side panel, and remove that panel.
2) Open the photo-paper holder on the left side, depress plastic tabs on its top and bottom so it can swing out 90 degrees, and remove it.
3) Remove 2 screws from the left-side panel, and remove the panel. This exposes the gears of the paper-handling mechanism; take care not to move the gears. Disconnect the three ribbon cables connected the bottom circuit board.
4) Flip up the LCD, exposing a screw. (Note that this one is shorter than all of the others.) Remove the screw. Lift the scanner lid and remove two screws just behind the rear of the glass. Close the cover. Lift the rear of the glass carrier, then slide it back slightly to remove it. Take care not to move the scanner bar that remains in the main body of the machine.
5) Keeping the lid shut, flip the glass carrier over over. Spray cleaner on the glass and wipe; repeat as needed. I use a bright light at a low angle to check for particles on the glass.
To reassemble, just reverse the steps. Finish by cleaning the top of the glass.
Paul Hays
Sep 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Glass Door stain
you can clean it but its not easy u have to remove the door put it on the floor remove the screws from the side and the bottom the glass should slide out then then u remove more screw to get the other piece of glass then u clean it and put it all back togather
Mar 16, 2009 | Kitchen Ranges
Lines all over second page
It is possible to clean the inner side of the glass. First you need to remove the scan module by removing two screws on each side, then remove the cable. Carefully take out the module. You will notice 4 small screws in the side, after removing which you can detach the LED module. Remove the vertical screws and this will detach the Lens Module. Now you will have access to the inner side of the glass. Ensure that the electronics, the Lens module and the LED are carefully placed back and cable connected properly. There is a small spring plate screwed along with the LED module, which needs to be placed properly. Please do not use any sharp instrument.
S. Mohan, Chennai, India
Jan 28, 2009 | Canon DR-5060F Pass-Through Scanner
Hotpoint side by side shelf removal
the bottom one should come up from the back first to get it out ,,, it may be stuck so be careful
Dec 12, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
HP 6110 All-In-One Printer
there should be two screws on the right side of where the glass, take them out, some models you also have to take the screws off of the left side since it is one piece, lift the whole unit With the glass and set aside to clean. ( With power off)
Oct 21, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
