Question about Epson Stylus RX580 InkJet Photo Printer
Paper jam I got a paper jam in my epson rx580 printer. How do I open it to get the paper out?
  • Anonymous Apr 14, 2008
    I have a paper jam. How do I open my printer?
  • Anonymous Feb 14, 2009
    I think I pulled out the paper - but still getting an error message. Don't know how to clear the jam. Sharon
I can not print CD/DVD lable bacause it jam, how can I fixed?
Posted on Jan 29, 2008
Turn off your printer and unplug the power cable. Open the scanner lid. Double check for any obstructions. Move the print head to the left side and check again if there's obstructions on the right side. Close the lid and try to turn on the printer. If error message still displays on the screen, possibly it is a printer issue. It may require service.
Dec 16, 2010 | Epson Stylus RX580 InkJet Photo Printer
My Epson Stylus Photo RX580 had a paper jam. I cleared it but now the screen keeps saying "Printer error has occurred. See your documentation". I've turned it off a few times and I don't know what needs...
1. turn it off & disconnect from computer
2. open printer & check for any obstructions
3. load a sheet of paper, press & hold the paper feed button while turning the printer on
4. it should print a test page, else the printer needs service as there might be some no-user serviceable parts inside that got damaged by the paper jam.
Apr 05, 2010 | Epson Stylus RX580 InkJet Photo Printer
DVD/CD Epson RX580 will not print
You need more than the printer driver.
Scanner driver
Epson print CD
Download the rest from here.
Feb 08, 2010 | Epson Stylus RX580 InkJet Photo Printer
My Epson rx580 stopped working.Message on screen states"a printer error has occurred.See your documentation". I do not have a paper jam. RRM
Not sure of your operating system ie xp vista or what system. sounds like a memory problem, ie large file like a picture or something, but you can try to reboot your computer (turn computer off and unplug) turn on. If this does not solve then easiest next step is to delete driver for printer (not just icon but software then reboot then reinstall. Good luck
Oct 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
10 to 15 sheets of paper jammed in printer rollers.
You will have to partially disassemble the printer. There are probably some bad rollers or springs and that is why it drew in so many pieces of paper to begin with. I normally only see three or four pieces drawn in at any one time.
Sep 26, 2009 | Epson Stylus RX580 InkJet Photo Printer
I have a paper jam error on my Epson RX580, but nothing is jammed? Any ideas?
drum gear for the transport are not meshed or has some debris in there
Jul 31, 2009 | Epson Stylus RX580 InkJet Photo Printer
Printer paper jam
Do a printer check by copying on standalone. means placing a document inside the scanner. Load 10 sheets of regular paper into the feeder then press the start button to begin copying. Try 2 copies. If it gives you the same error, then there is already an issue with the gear inside the printer.
If your unit is not under warranty anymore, log on to Click on help me find a service center to the right of the page. You will have to put in your zip code to find an epson certified servicer near to your area.
If your unit is not a year old yet, please call epson technical support.
If it copied successfully, it could be just the paper settings, or the type of paper that you are using is not supported or you might have to uninstall and re-install drivers.
May 06, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus RX580 InkJet Photo Printer Logo
233 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
