Question about Car Audio & Video
The Pioneer GM-5100T wiring help?!!
I have this amp, the Pioneer GM-5100T, but I dont have the plugs for the wire input. I got this amp from a friend but didnt get that. If I can get a link to a wiring guide or if someone can tell me what hooks up to what parts I would be soo thankful! Im getting 2 15' dual kickers and I need something good to power them! Thanks for help. chrisshumate@mchsi.com
  • 1,068 Answers
I just sent you the manual for your am everything you need to know is in there. i also have tht plug if you need it. but will only be used for high level inputs for factory radio's if you have a after market radio use your rca jacks. or if you want you could use a converter if you have a factory radio that makes speakers outputs from the radiointo rca jack that will go into the amp. the rca'sare the best way it will sound much cleaner. good luck
Posted on Sep 27, 2009
My amp keeps blowing its fuses whenits plugged in
Go over all your wiring. Make sure your power wire isn't grounded somewhere. If your power wire is touching any bare metal it will spark and blow the fuse the second you touch the power to your amp. Make sure your in-line fuse is about a foot from your battery, and make sure you have your ground wire grounded securely to the main chassis of the car/truck and that it is either same size gauge as your power or even a little bit bigger gauge. Also make sure no strands of wire from your ground or power wire are loose and reaching over touching the other where you plug them into the amp. If the ground and power touch eachother they will blow the fuse and possibly cause permanent damage to the amp.
Jan 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Wont power on
Ssometimes the antenna wire is not enough to turn on the amp , some cars use relays in thier power antenna turn on set up which require low 500 ma 's . hit the amps turn on post with 12 volts directly from a jumper wire with alligator clips from main poower wire , if it still wont tunr on the amp the amp may be faulty , also check amps ground , metal its grounded must be free of paint , undercoating rug ect ....
Nov 17, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hi i have 760w pioneer that i am selling but i dont think it works because the red light does not come on when the wires are connected..are they're special wires that should be used for it to be connected?...
IF THE WIRING WAS RIGHT, THOUGH THE WIRE SIZE HE USE TO CHECK WAS NOT PERFACT, IT SHOULD HAD COME ON FOR ATLIST AS TESTING RESULT, CHECK THE WIRING AGAIN, AND FUSE..HOPE IT WORKS
Oct 13, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
