Question about Kenmore 62602 Electric Dryer
Need the chip for hot air - Kenmore 62602 Electric Dryer
  • Kenmore Master
  • 8,220 Answers
Compaq cq-45 laptop light near to caps and scroll blinks , No display
In Most cases this happens when using Nvidia graphics.
You need to open your laptop - call a technician for professional Job is you are not able to do so.
After removing the cooler which usually comes with a small fan (covers the main processor), remove the processor and you will see a chip that need a "HOT AIR STATION" this tool blows very high temperature of air on the surface.
well I used my wifes Hand Hair Dryer - also does the magic.
see image on where to blow the hot air.
now after blowing the hot air, mount your laptop again.
but first, let it cool down.
Sep 04, 2013 | Compaq Presario CQ-45 Laptop Universal AC...
Tip
Intel 845gvsr mainboard no display problem
this problem is normal because of the BIOS chip failure normally
symptoms:
when u get ram out and start computer it gives beeps and when u put back the ram and power on PC it gives no beep no display.
Fix the problem:
tools required:
1. hot air gun
2. 512kb fresh bios chip/ if the old chip is right then no need of newer one
3. p3 mainboard (with the BIOS socket) for reprogramming the chip
4. dos bootable hard disk
5. bios bin file.
have not the file ,
don't worry: this file can be made from the bios chip of a working mainboard using the bios flash utility.
flashing software: best is Uniflash.
Procedure:
1. with hot gun, get the bios chip out of the board,
2. reprogramme the chio with correct bin file.
3. put the bios back
Reprogramming:
copy the file in dos bootable hd
run the hdd on p-3 board
pull the bios out of running board (with slight care)
put the 845gvsr bios chip in place of p-3 bios
run uniflash and flash the bios
power of p-3 computer and get bios out
for how toprogramme bios chip : check the page
http://www.pcnineoneone.com/howto/biosflash1.html
on Jan 24, 2010 | Computers & Internet
How do you remove a chip from a mother board to scrap
You need a hot air gun to melt the solder underneath the chips.
Feb 11, 2012 | Computers & Internet
OK my X-box 360 is screwed when i take off the cover and stuff there this white thing that directs the air to the motor thing, if i take that off it doesn't get hot but it also gets to red lights, but if...
you have first signs of red ring of death. You need to get a hot air gun and heat up the chips under the radiators and maybe do xclamp mod. let cool put back together and should work.
Nov 21, 2010 | Microsoft Xbox 360 Console
Where do i put the chips in the water
the wood chips should be soaked first for a charcoal set up, they go right on top of the hot coals...for an electric model (no charcoal needed), there is no need to soak the chips. There is usually an access port that you slide in & turn to dump. Then...TAKE THE TUBE OUT so you have air flow.
Apr 19, 2010 | Brinkmann Smoke 'n Grill 810-5304-E
Shuts off suddenly
Well the laptop shuts down suddenly so as to protect your CPU chip from getting fried. It's caused by overheating due to dust or improper chips contact with copper pipe.
You need to take the laptop apart & clean it particularly the air vent allowing hot air to move out.
Then you need to see if the CPU chip & (sometimes the chip on the motherboard), is having good contact with the copper pipe. If it's the case, you need to apply a good thermal grease on the chips after cleaning the old grease. Replace back all the stuffs back again.
Please send us your feedback & vote to help us help you as it should be.
Feb 11, 2010 | Toshiba Satellite M60 Notebook
It says system error E 74 and theres a red light that keeps blinking and it wont let me do anything
That my friend is an AV issue that lies between the HANA chip and the GPU. It can be either of the two. Personally, I flux and re-flow both chips by hot air and then x-clamp mod the heatsink. Be careful with this method, because damage can be caused to the chips when temperatures get too high. There are several online tutorials for this. On the other hand the X-clamp might work alone, but since that is more of a temp fix alone I would go the other route with hot air or get someone to fix it for you. I hope this helps.
Feb 01, 2010 | Microsoft Xbox Console
Has enough freon but still blows hot air,whats wrong with my air?
First you need to make sure your testing you ac when the car is on. If its still blowing hot air make sure you have the ac setting set and not the fan setting. If thats not the problem make sure the compressor in the ac is running it give off this distinct humming sound when the ac is turned on, you might need to put your ear next to it if you can find it. If the compressor isn't working check the wiring in the car, and make sure the fuse/chip for the compressor are fine.
Jun 19, 2009 | 1999 Ford Explorer
Sony ericsson k500i
Theres a problem with the cellphones flash memory chip, you need to hot air solder it, or if the problem persists, you need to replace the chip. I also have a K500i, I'm still using it. I just hot air it and runs fine until then.
Feb 18, 2008 | Cell Phones
Won't turn on
theres a problem with flash memory chip on the cellphones board, you need to hot air solder it, but if this didn't work the chip is damage and it needs to be replace
Dec 16, 2007 | Motorola Mobility L2 Cellular Phone
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
