Question about Pyramid PS-7KX Regulated 12V 5Amp Power Supply Power Supply
What i have to do if protection light is on/ - Pyramid PS-7KX Regulated 12V 5Amp Power Supply Power Supply
  • 52 Answers
One of your power transistors might have gone short circuit, You will have to have them repaced.
Posted on Sep 27, 2009
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Where is the fuses on a suzuki c90t
According to the 2007 owners manual for my C90T there is a 30A main fuse located behind the left upper cover. To access the main fuse lift the fuel tank lid and remove the six bolts that are holding the left and right tank covers in place (not the screws that are located under the fuel cap) then remove the two screws on the front of the speedometer/fuel inlet cover (they face the base of the handlebar risers) then remove the left tank cover and left upper cover by removing the screw at the base of the left upper cover. One 30A spare fuse should be located in the main fuse box. To access the fuse bank containing the other six fuses remove the right crank case cover, once it is cool to the touch. One 10A and one 15A spare fuse should be located in the main fuse box. Fuse list: 30A MAIN fuse protects all circuits; 10A HEAD-HI fuse protects the headlight high beam and headlight high beam indicator light; 10A HEAD-LO fuse protects the headlight low beam; 10A FUEL fuse protects the ECU, fuel pump, injectors, neutral indicator light and oil pressure indicator light; 15A IGNITION fuse protects the fuel pump relay, starter relay, ignition coils, decomp relay and solenoid; 15A SIGNAL fuse protects the turn signal indicator light, FI indicator light, speedometer lights, brake light/tail light and horn; 10A POWER SOURCE fuse protects the electrical accessories connected to the output terminal
Aug 13, 2011 | 2005 Suzuki Boulevard C90T
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
I have a dual electronics 4 channel amp that goes into protect mode as soon as i throw power to it
unplug all the speaker from amp then power on. if you still have a protect light amp is bad and if you have no protect light continue to hook up each speaker one by one while amp is on till you get a protection light and that speaker would be the source of your problem
Jun 02, 2010 | Dual Car Audio & Video
Protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 29, 2010 | Rockford Fosgate Power 1001BD Car Audio...
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Model c-700 It turns on but the protect light dosent come on. What's wrong with it
protect light only comes on when theres a short or bad earth as long as power light on your all good you never wanna see protect light on cheers mate]
Oct 17, 2009 | Boss REV-700 Car Audio Amplifier
Protective gear safety
ALWAYS wear protective clothing, including: * Leg protection such as chaps, leggings or cut resistant pants. * Hard hat if there's any material overhead. * Gloves or mittens with an enhanced gripping surface. * Eye protection with side shields. * Hearing protection such as earplugs or earmuffs. * Boots or shoes with steel toes and nonskid soles.
Aug 27, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
Mac-505 amp
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Dec 19, 2007 | Car Audio & Video
Pyramid PS-7KX Regulated 12V 5Amp Power Supply Power Supply Logo
166 people viewed this question
Top Pyramid Computers & Internet Experts
BJ Russell
Jason Morris
Are you a Pyramid Computer and Internet Expert? Answer questions, earn points and help others
