Question about Duke 59-E4Z Electric Single Oven
Duke Convection Oven won't heat past 250 degrees
Just curious if your problem is fixed. I'm having the same problem.
It was brand new 5 months ago... Just started trying to use it. It either shuts down around 250 degrees, or when you open the door. Then it acts like a fuse blew. Turning it to Cool Down brings it back to life, but condition persists.
  • stgemme Sep 27, 2009
    Sorry, I should have been more clear. I was referring to Fahrenheit.
  • 3 Answers
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Posted on Sep 27, 2009
2 Suggested Answers
SOURCE: Duke Convection Oven won't heat past 250 degrees
Most likely a heating element.
Posted on Nov 08, 2009
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Duke 59-E4Z Electric Single Oven Logo
182 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Duke Oven Expert? Answer questions, earn points and help others
