Question about Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass
Thumb latch and component are in tact but it keeps slipping out
They are both fine but sometimes it will work then when I put it back together it freezes again.
  • 152 Answers
When you tighten the screws you have to be sure that the two sides stay aligned. try to tighten the screws a little at a time and keep testing the lever as you go. you will notice that there is a little play frome side to side or up down so it is critcal that you maintatin alignment untill the screws are tight.
Posted on Dec 01, 2009
"How do I put this back together Door lock latch diagrams"
does it look anything like this , sorry hav'nt got the item list , get a workshop manual if this is not helpful , keep me posted if you wish
Jun 02, 2014 | 2001 Chrysler PT Cruiser
The nut which holds the quick release latch which is spring-loaded on the top of my Maxell tripod fell off and I can't seem to put all the part back together so it works correctly.
You could give us a call at Spartan Photo Center, we might be able to guide you through putting it back together. You could also ship it in to us and we could put it back together for you. You can contact us at 864-583-6835
Feb 18, 2013 | Camera Maxell Tripod With Bubble Level 20"...
The sleve that holds a 1/4" bit came out and will
That's called a 'collet'. Sometimes you have to squeeze a collet to get it to go where you need to, but look both the 1/2" and 1/4" collets over carefully for a burr or flat spot that is causing them to not go together first.
If you see a spot that's keeping them from going together, work it on a fine oilstone. Any little irregularity can keep a collet chuck from gripping the tool well, so you want to be sure that there is no damage to them, also that there is no sawdust or sawdust residue in either collet. Once a collet tightens unevenly the tool will slip and you'll have trouble with it forever.
Once all is well, just get your little pair of Vise Grips and give it a gentle squeeze and it should slip right in.
If that doesn't do it, get back to me on the 'comments' tab and we'll go from there.
lp
Jan 11, 2011 | Makita & Plunge Router
2003 Toyota Corolla. Trunk won't stay closed. Latch seems to work fine.
must have a broken spring in the latch tha'ts how it works a spring keeps the locking teeth together.replace the latch.
Nov 25, 2010 | 2004 Toyota Corolla
Does the breadman tr845 use a belt to turn the dough mechanism? if so where can i buy one?
Yes, the Breadman TR845 uses a belt to connect the knead paddle to the motor. I had a problem with my Breadman so I took it apart. It turned out for me that the belt was fine but it had slipped off the plastic gear. The belt was still around the shaft of the motor so it could only turn if the bread pan was empty. The belt is a timing belt with integral teeth. I needed a small space washer that would keep the black plastic gear from slipping on the shaft and allowing the belt to slip off the gear. There is a lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacer washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed it to be 1/4 tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft of the motor. The spacer keeps the black plastic gear from sliding and it keeps the belt from slipping off the gear. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are losts of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Jan 17, 2010 | Breadman TR845 Bread Maker
Brush won't turn
Even though the belt is still in tact, that doesn't mean that it is still good. The belt needs to be replaced with a new one because it is stretched. It is probably slipping on the beater bar.
Jim
Nov 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Driver side second row seat will not fold down or adjust.
I had the same problem.The dealer wanted $400 to replace the latch. I didn't wnat to pay that much so I looked at it and found that the release strap was twisted and jammed in the mechanism. Here's how I fixed it.
I removed the screw from the lever and removed the lever. I pulled apart the plastic housing. It does not come apart all the way but enough to work on it. Pull the release strap that comes out of the back and pull it clear of the mechanism and straighten it out. slip the lever back on and the seat should fold. Fold it up all the way to make it easier to reassemble. Pull the lever back off and slip the release strap back into the slot and make sure it is not twisted or kinked. Snap the housing back together, put the lever back on, and screw it in. Test it and it should work fine. Hope this helps,
Aug 03, 2009 | 2005 Ford Freestyle
Driver side second row seat will not fold down. When pulling the release catch the seat does not release . I can not fold the seat flat to carry a large load in the rear of the vehicle.
I had the same problem. The dealer wanted $400 to replace the latch. I didn't wnat to pay that much so I looked at it and found that the release strap was twisted and jammed in the mechanism. Here's how I fixed it.
Jul 31, 2009 | 2005 Ford Freestyle
I have a Kenmore dishwasher model # 665.16512202, The handle or latch is slack and it will not close. I've looked at diagrams and all the parts seem in tact but when I place the latch/handle assembly back...
Have you checked the latch as well. Make sure the lever lines up with the latch and seats deep enough. No obstructions at the lower hinges as well.
Jan 03, 2009 | Dishwashers
Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Oct 07, 2008 | Kodak EasyShare DX7630 Digital Camera
Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass Logo
429 people viewed this question
Top Baldwin Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Baldwin Electrical Supply Expert? Answer questions, earn points and help others
