Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
We watch the tv for about an hour then it turns its self off.
Then after a few seconds it turns back on with a distorted pic.
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: TV won't come back on
That model has had some issues with a defective flyback. Thats quite possibly what the problem is. If you need more info let me know
Posted on May 16, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA tv will not stay on
Sounds like the flyback very famous for that model. You need Flyback 270125 you can get the new RCA flyback at the following link and they provide step by step detailed indtructions on how to do the repair. Heres the link to your flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/270125/cName/flybacks
Posted on Jun 18, 2009
quintonizaak
  • 319 Answers
SOURCE: The t.v shuts its self off
How long does it take to switch off,and is there sound when switching off
Posted on Nov 18, 2011
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
Picture goes diagonal
U know how to solders?Ur convergence it dead,must replaced.Tries these websites for convergence kit.Tv repair World.com,Tv repair kits.
Nov 13, 2009 | Toshiba 50HM66 52" Television
Powers off intermitantly
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Picture fails
hi,
sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
J
Jul 12, 2008 | Philips Televison & Video
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
RCA F31317 31" TV Turning self off and on then completely off
the horzantle power supply is bad probably missing the B+ voltage this is a repair for a tech high voltage
Dec 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
