Question about Garmin nuvi 200W GPS Receiver
My gps is not responding to touch prompts on the screen.
My gps turns on and off but appears to be frozen. It is not responding to touch screen prompts.
    President:
  • 1,111 Answers
Plug it in to the usb port on your computer for a few hours. then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update
(actually i would do this either way)
bill
Posted on Sep 27, 2009
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Touchscreen don't work..
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Jul 30, 2010 | Garmin nuvi 255W GPS Receiver
Magellan screen frozen
assuming you have the 2200 as listed in your category, depending when your 2200t was made, it could either have a push type (one you would use a paper clip to reset) or a slide switch.
both are located in the same position (on the left side, bottom under the flap right under the sd card slot)
turn on the gps till you get to the warning screen, then reset it.
if its is the early model with the slide switch, youll have to move it back to the other position and restart it..
if that fails, i would try the latest update, well actually i would install the update either way, whether the reset works or not.
you can get the update HERE
let me know if you need further help
bill
May 24, 2010 | Magellan RoadMate 2200T GPS Receiver
My garmin (nuvi 670) touchscreen does not respond to any touch
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
My screen does not respond to my touch
You need to Calibrate the touch screen.1Turn off the Nuvi. 2 Turn on the Nuvi and hold the Power key to the left for about 30 seconds untill the calibration screen appears (white screen with "Press dot")
Nov 08, 2009 | Garmin nuvi 255W GPS Receiver
Touch screen seems to be frozen. IT does not respond.
On my NUVI 265wt you turn on the power to the left and hold for about 30 seconds until the calibration screen appears and then "Press dot".
Jul 17, 2009 | GPS
My GPS just stopped responding to touch.
can you soft or hard re-boot your GPS?
(usually by holding down the down button + menu)
Jul 02, 2009 | GPS
Garmin touchscreen
This was just suggested for the exact same problem with my StreetPilot 2620 and worked like a charm: (1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored. Thank you for rating this solution. Good luck and save you $250 for something else!
Jun 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touch Screen Issue
Hi Troy, same problem with my 2610, It seems to be related to a voltage problem in my ford f-150 07. When starting the truck I think it sends current the wrong way because if i start and turn off the truck it goes back to normal, the problem comes back if i start the truck with the 2610 on. If this can help, the garmin tech also told me about the 225$ repair. Try turning the unit on and off and also your vehicule. Once it is ok, dont forget to turn the unit on and off while the car is on. It worked for me. I also know that this is not a definitive solution but it can help. Patrick
May 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
166 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
