Question about Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50
I have a trimatron dimmer which has a black, red, green and another red wire labeled 3 way. My box has two black , white, red and groud wire. this room has two seperate light switches that control the light. Which wires go to which wires?
    Sniper:
  • 66 Answers
When you take the existing switch out of the wall, the existing switch will have one black screw and two gold screws. The wire that is connected to the black screw of the existing switch (probably on of the black wires from the box) connects to the black wire on the new dimmer. The other two wires (one black and one red from the box) that are connected to the two gold screws on the existing switch will connect to the two red wires on the new dimmer. Basically, wire from black screw goes to new black wire and wires from gold screws go to new red wires.
Posted on Oct 09, 2009
How do I install a trimatron light switch that has a black wire a green wire and a red wire and the house box has two black wires and a red wire
If the main box has 2 blacks and a red i would assume that the first black is either the live or the final wire that goes to the light. the other black and red sound like traveller wires that are either or wires for a 3 way switch system. 3 way switches are used on both ends of a hallway or for the top and bottom of a stairwell. You have to purchase a special 3 way dimmer to put in that area... or better yet buy 2 so that you can undim the light from the other end if needed.
Oct 06, 2013 | Electrical Supplies
Trimatron 3 way push on off dimmer switch
That means you have taken a 3 way switch off and you need to purchase a 3 way dimmer.
Jun 22, 2013 | Electrical Supplies
I'M REPLACING AN OLD LEVITON ROTARY DIMMER WITH A LUTRON PADDLE DIMMER. THIS IS A 3-WAY SWITCH. THE ROTARY DIMMER HAS 2 BLACK WIRES, 1 RED, AND 1 GREEN. THE NEW DIMMER HAS 1 BLACK WIRE, 1 RED, 1...
with a three way switch like this, you will have two traveller wires and a common wire. Look in the instructions for the switch or on the back of the device itself to see if there is a wire labeled "common" or "com". This common wire from the old switch hooks up to the common wire on the new switch. I did a bit of searching on the leviton 6602, but couldn't find anything specifically about the three way version (I would venture to guess, however, that the red wire on the old switch is the common). The common on one of the three way switches will always be a constant hot (or power) wire...the common on the other three way switch will be the "switch leg" or the wire that connects directly to the light. The two travellers go to the other two wires. Check the pamplet that came with the lutron device, it should show which wire is common and which are travellers.
Sep 24, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I am replacing a two way switch with a two way Trimatron dimmer 6681 The dimmer has 1 black wire hot, 2 red wires and a ground (green) The box has 2 black, 1 red and 2 white What do you connect...
The best thing you can do in that situation is match the wire colors of the dimmer to the colors of the screw terminals on the switch you removed. Unfortunately, its too late for that - so here's my best guess: One of the black wires in the box will be coming from the same romex cable as the red wire. Take THAT black box wire and connect it to one of the red wires on the dimmer. Take the red box wire and connect it to the remaining red wire on the dimmer. Connect the black dimmer wire to the remaining black wire in the box. The two white connectors in the box get tied together - they don't get tied to the dimmer. And the ground (green) wire on the dimmer just connects to the bare ground connection in the box itself - or to the metal backbox - or cut it off and don't use it.
Jul 15, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
The house has a red and black wire the trimatron has2 black one green am i missing a wire or does one black not get hooked up?
Rotary dimmers have 2 black wires, and the color-code tells electrician that both blacks are interchangeable.
This means that dimmer is for single pole only. That dimmer will not work for 3-way switching where more than 1 'switch' controls same Load (light fan motor)
Connect either black dimmer wire to the red, and connect other black dimmer wire to the black.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Two red wires, 1 black wire and a green wire. In the box in the wall I have two black wire and 1 white. What do I connect to what? Help. This is for an electric box that has 1 click on/ off switch and...
make sure your application is correct first,this switch is controlled from at least 2 locations,you cant put 2 dimmers on the same light,if you have taken the wires directly off the switch you will wire the white to the black of the dimmer and the 2 reds to each of the other wires,the white in this case is you pivot or constant hot,the other wires are the travelers
Feb 07, 2011 | Cooper Wiring Devices ACE 3WAY ROTARY PUSH...
I have a black wire a white wire and a ground
The red wire is your chase wire and needs to go all the way to the other switch
Mar 07, 2010 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
One wire is the common and the other two are the travelers.The trick is to find which one is which.... If you can see into the electrical box check to see if one of the red wires and the black wire are from the same cable, if they are then more than likely those two wires are the travelers; you can also look at the other switch and see which two wires are on the brass colored screws, those would also be travelers. The common is usually the wire that is on the black colored screw. Once you figure out which wire is your common, I'm thinking that it is one of your red wires, you would attach that wire to the black wire on the dimmer and the other two wires to the 2 red wires on your dimmer.
Aug 19, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Single Pole Dimmer Installation
I'm not sure if this is going to work in your case, but I'm pretty sure it will...
Green to ground (probably bare)
Black to black
White to the red that's not labeled 3-way
wire nut on the red labeled 3-way
That should fixya!
May 28, 2009 | Solar Levitron Decorator Style Slide...
I have the Trimatron Dimmer switch to install,
one black from the dimmer to black. the other black from the dimmer connected to red. the green connected to the bare wire.
Mar 20, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50 Logo
511 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
