Question about Jenn-Air Ovens
I have a Jenn-Air JMV8208BAS microwave that is only a little over a year old. I just recently noticed that the "beep" noise it makes has diminished to a very feeble beep sound that can barely be heard. This is the noise you hear when you press the keypad or the warning it gives when the timer has run out and it quits running. I would swear when I had this installed there was a choice for a "high or low" beep sound, but I cannot find that setting now in the setup or in the owner's manual. Also the clock display appears really dim too and I thought there was a brigh/dim setting for that too and I can't find it. I did buy the extended warranty on this, so if something has gone out I should get it covered. Thanks for your help. Dave, Phoenix, AZ
    Top Expert:
  • Jenn-Air Master
  • 26,753 Answers
Sounds like a power supply fault to me. Get it repaired under your warranty agreement.
Posted on Mar 23, 2017
SOURCE: jenn air oven display
Temporary solution, rapping on the display brings it back to normal for about a day. Certainly not a permanent fix, though.
Posted on Mar 03, 2008
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
localwonder
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
  • 3 Answers
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
I replace the C3 Capacitor on the display circuit board of a Jenn Air model #JJW9627AAW - double oven from Sears after the display got too dimm. This cost me $1.50 total verses the $200 parts cost only.
Thanks for the tip man!
Posted on Sep 20, 2009
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
What wrong when a jenn air convection over fan make noise
What kind of noise? Has the type of noise it's making different now then previously?
Nov 19, 2013 | Jenn-Air Ovens
Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Dec 30, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
395 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
