Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Brake acts like it's not releasing fully...holding mower back like the belt is slipping...just replaced drive belt and it's still doing it.
  • 169 Answers
The brake caliper is rusted closed causing the pads to stay enguaged, dissasemble the brake caliper and remove the 2 pins and de-rust them with emory cloth. reinstall them with anti-seze and reasemble the brake caliper back onto the transmission should be good to go!
Posted on Nov 22, 2009
  • 472 Answers
SOUNDS LIKE THE BRACK IS STICKING ON THE SIDE OF THE TRANS IS ITS 1/2 NUT TURN A LITTEL NOT TO MUCH OR WONT STOP
Posted on Sep 30, 2009
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
Ignition/no spark on ford GT85 riding mower with a kohler M18QS gas engine. I need the electrical schematics for diagnostics.
follow this steps and fix it. GOD BLESS YOU
If grass is poorly or unevenly cut, try mowing at a slower speed and adjusting the engine speed with instructions in your owner's manual. Scrape away any dried grass and other debris caked under the mower deck. Sharpen or replace dull or bent blades 0fbc95da-10ce-4268-a804-bcc52ffe7dcf.jpg. Check and replace a worn belt.
If the V-belt slips or comes off during use, clear any debris in the belt area, adjust the drive-belt tension (see below), or have the belt replaced. Adjust and tighten pulley fasteners or have a service center replace worn parts.
If the belt squeals or wears excessively, adjust the drive-belt tension (see below) and look for obstructions around the belt. If that doesn't work, take the mower in for professional service.
If the mower vibrates excessively when the clutch is engaged, scrape away any debris accumulated under the deck. Balance the blade and replace the blade if needed. If that fails, adjust drive-belt tension (see below). If you find that the drive belt, pulley, or other belt-drive part is damaged, consider having it replaced by a professional.
If the mower is hard to shift or doesn't move when the clutch is engaged, adjust the drive-belt tension (see below). Also make sure the mower is lubricated according to the owner's manual specifications. As needed, have the mower serviced for damaged or maladjusted clutch/brake pedal linkage.
If the engine doesn't start, loses power, or dies during use.
Replace a recoil starter rope:
  1. Disconnect the spark plug cable for safety.
  2. Disengage the throttle cable from the housing and remove the housing as needed to access the starter.
  3. Remove the handle from the rope, which is often held in place by a knot or retainer pin.
  4. Unfasten the other end of the rope from the starter using pliers or a cutter as needed.
  5. Knot the end of the replacement rope.
  6. Tighten the pulley counterclockwise all the way, then back it off two turns and hold it firmly.
  7. Thread the unknotted rope end through the pulley hole.
  8. Thread the rope through the housing hole and pull it taut.
  9. Slowly release the pulley, allowing the rope to wind around the pulley.
  10. Attach the handle and reassemble as needed.
  11. Reconnect the spark plug cable.
Replace a recoil starter spring:
  2. Remove the housing and the spring cover.
  3. Carefully remove the rope from the pulley to release spring tension.
  4. Remove and replace the spring as recommended by the manufacturer.
  5. Reinstall the pulley, rope, and housing following the instructions above.
  6. Reconnect the spark plug cable.
Nov 12, 2013 | Garden
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Tried takinf the machine out of the shed and found that the machine starts and runs as normal, but the tractor will not drive forward, or back. Diff apears ok as one wheel is trned by hand the other...
Hi, if you can't push the mower there is a short lever on the right hand side of the diff that the brake pedal is attached to, make sure it is not seized forward. If you can push the mower, start the mower and with it in neutral, select top speed, fully release the clutch/brake pedal, push the pedal hard forward again then select any gear and release the pedal again. This resetsthe vari-speed pulley. If none of this works check that the rear drive belt idler pulley arm is free. Hope this helps, regards Phil.
Aug 19, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Belt slips on bolens riding mower has new belt
there is a belt which drives the deck/blades, and another belt which transfers power to the transmission to move the mower. you do not specify which belt, but as they both have a tensioner, you need to locate the pulley which removes the slack from the belt and replace it and the spring which provides the tension. you had to release this tension in order to install the belt so you know exactly where it is. oftentimes a close examination will reveal that the belt was not put back on correctly. if it was slipping already, you replaced the belt and it is no better then replace the tension spring. if it was working fine and the belt broke due to wear and now it is a new belt and slipping i would closely examine the path of the belt all the way around and make sure it is in right. often times there are small dowel shaped steel keepers and guides which are supposed to hold the belt in but the belt has inadvertently been routed around them which makes it slip.
good luck
Apr 13, 2011 | Garden
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Drive belt is too loose, already replaced belt and pulley. no drive power, plenty of deck power. Tractor is 8-10 years old, drive pulley portion of the double engine pulley split, so I replaced it and...
I had the same problem with my Craftsman Lawn Tractor. The Drive Belt (which is not adjustable) is only engaged when the Brake Pedal is released (the Brake Pedal is located on the left side of the tractor, near the foot rest on my Tractor).
The Symptoms: My Tractor lacked driving power, and would not go up an incline, but the mower deck was powerful and working fine, even though the Tractor seemed to lack power and moved slower than usual, and would not travel up an incline.
I too, changed the Drive Belt, which initially seemed to help somewhat for a very short period of time, and then the same, lack of power problem, re-appeared again. The belt was not the problem, but only seemed to work somewhat due to the rougher texture of the belt's surface against the pulleys.
I also changed the Plastic Clutch Pulleys that engage the Drive Belt, thinking that they may have been worn down to a point that the Drive Belt could not fully engage with these Pulleys. No Luck.
NO ONE, NOT EVEN SEARS ON-LINE REPAIR ADVICE CENTER HAD A SOLUTION. THIS WAS VERY FRUSTRATING INDEED.
There had to be a solution: After much investigation, I eventually discovered the problem, which actually was easy to solve, and I would like to share this simple solution with others facing this same Frustrating Problem.
The Brake Pedal, when released, causes the Drive Belt Clutch Pulleys to move, and thus Tighten the Drive Belt. When you look under the Tractor, there is a Protective Metal Plate mounted to the Bottom of the Main Tractor Frame which covers the Brake Pedal Shaft and attached Mechanisms. Over time, Grass Builds up in between the Protective Metal Plate and the Tractor's Main Frame Deck, creating a very narrow space between these two pieces of metal.
This area is very difficult to get at, and almost impossible to clean out. Over time, Grass Clippings accumulate in this hidden area, and harden to an almost rock hard clump.
These Hardened Clippings accumulated between the Brake Pedal Mechanism and its fully released metal stop position. Thus, preventing the Brake Pedal Mechanism from moving to its fully engaged position.
I used a long screw driver to break up the compacted grass clippings, and an Air Compressor Blow Gun to break up the packed grass and blow the area clear. It takes awhile to do this cleanup, and is a bit messy, so do it outside, but be patient, and be sure to clean out all the grass that is lodged in this hidden area.
What was happening was that the Packed Grass was so dense that the Brake Pedal could not Fully Release, thus only Partially Engaging the Clutch Pulleys and the Drive Belt, hence the appearance of a loose Drive Belt even when the Brake Pedal was released.
Once the Packed Grass Debris was cleaned out, you will immediately notice the Drive Belt being tighter than it was previously when the Brake Pedal is released, and when you test drive the Tractor you'll find that everything works perfectly, like it was brand new.
Good Luck...
Rayko
Jul 15, 2010 | Craftsman Garden
Belt jump off the drive pulley
I don't have this kind of mower. But I was faced with the same problem recently. I got my belt back on by taking a large wrench and affixing it to the bolt head holding the pulley which you want to slip the belt on. Hold the belt firmly against the pulley and turn the wrench and the belt in the grove will walk around the pulley until it slips in place.
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
138 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
