Question about GE Profile Harmony DPGT750GC Gas Dryer
GE harmony DPGT750GCIPL Gas dryer no heat and 3 intermitnt codes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Been researching various diy sites and have used the field service mode and disassemble and reassembled this complex unit. The problem started with intermittent heating. Then no heat would come on. Field service mode has found different errors at different times. At first it just said "The blower is not getting up to speed". Last night I discovered there was a "more" option in the service mode report and I found another error, "The appears to be no gasflow..." so I replaced a redundant safety shutoff in the gas line with a straight nipple and after running for a while the unit's blower kicked in and the gas fired. Thought it was fixed, then this morning its not firing again and ran the service mode and it shows the previous stated 2 errors an now, a third message is, "there is a problem with the inlet thermistor". This thing is driving me crazy...just picked it up used and should've stuck with the basic dryer model!! HELP!! heading out to the laudrymat now. Oh also, resistance on motor is correct per the tech service guide test. Can I test the blower motor by hot wiring it to be sure it's bad? I thought the prblm was blower motor or inverter but want to be sure which one before I go and buy and replace something!! Now maybe it’s the inlet thermistor too?? Can the inlet thermistor cause all these problems?
4 Suggested Answers
SOURCE: GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Posted on Mar 23, 2010
coleelliott
  • 20 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
Posted on May 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a problem with the dryer not heating up.
Number 711 is the ignitor.
A silicone carbide ignitor
Profile service manual link
Posted on Oct 03, 2010
Clothes aren't drying .
Here's what you need to do, I'm very experienced with this particular brand/model dryer:
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
Clean the heck out of your duct even if there is nothing blocking it. Also, excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out that build up inside your dryer.
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
http://genet.geappliances.com/DocSearch/Dispatcher
Best of Luck!
Apr 23, 2009 | GE Profile Harmony DPGT750EC Electric...
Tip
Are you having problems with your GE Profile Harmony but don't know where to start to troubleshoot? Let the dryer do it for you, here's how:
The system will give you a description of possible hardware failure and troublecode.
Replace the failed piece of hardware and plug your system back in. It will go through a boot-up sequence and verify that your machine is working once again.
on Apr 30, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Tip
GE Profile Harmony DPGT750EC (Electric)
on Apr 30, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer runs but no air circulating
love2fix,
First use the dryers service mode and make sure that you are getting the same information as you suspect:
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
Best of luck!
Apr 15, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony gas dryer heats up but blower work 2 min. then stops
Have you access the dryers service mode? If not, access it and see what error code you get. Follow this:
Once you know the error code, post it or email me and I can help you from there. jeryflores@hotmail.com
Apr 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile dryer dpgt750gc1pl
Is your dryer gas or electric? I think based on your model number, it possibly looks like your dryer is gas. Regardless, you need to look at what the service mode troubleshooter tells you. To access it:
Let me know what it tells you and I can help you further from there.
Apr 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Same no heat no blowing
Dec 17, 2008 | GE Profile Harmony DPGT750EC Electric...
Blower doesn't blow and no heat
With these GE Harmony Profiles, the blower is the problem in same situations about 95% of the time.
Oct 18, 2008 | GE Profile Harmony DPGT750EC Electric...
Ge harmony dryer not heating up dpgt750ec1pl
Mar 12, 2008 | GE Profile Harmony DPGT750EC Electric...
How do you enter into the diagnostic mode
Dec 22, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750GC Gas Dryer Logo
232 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
