Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer: 120vac going into ccu nothing out, no "click" noise when plugged in.No display ? Is the CCU bad and if so what is the best way to get the door open as There's a load in there that needs to go into the drier
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
F01 CODE ON WHIRLPOOL MODEL# WFW8500SR00 FRONTLOAD DUET SPORT HT, ALLREADY CHANGED THE PUMP MOTOR
ERROR CODE F01
The pump driver fails to activate/One of the main relays is not working properly/
A communication error between the Central Control Unit (CCU) and the EEPROM
onboard the CCU occurred.
Check for loose power outlet. A loose power plug in the wall can create
line noise and issues.
- Check if washer is on a dedicated circuit. Other devices on same circuit
can create line noise and cause this issue.
- Unplug washer or disconnect power.
- Make sure that wire harness connections from the CCU are not broken or with wires
detached, and that connector internal pins are visible.
- Make sure all green wires (ground harness system) are not broken or detached.
- Make sure the two ground switches are pressed correctly by the toe and rear panels.
- Make sure all connectors are fully seated.
- Plug in washer or reconnect power.
- Check for power going to Central Control Unit (CCU) by listening for a click in the
CCU when unit is plugged in washer or when reconnecting power.
If no click is heard, replace the CCU. Here is the part to order.
Oct 10, 2013 | Washing Machines
No display only a ticking noise
You will need to replace the CCU on the unit. Here is the part to order.
To replace the CCU, just remove the top and you will see it.
Dec 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F 01 fault code on front load washer
ERROR CODE F01
- Verify unit operation by performing the Diagnostic Test.
- After the diagnostic test has finished, unplug washer or disconnect power
and wait for 15 seconds.
The CCU is located under the top panel which you already removed. Here is the part to order.
Nov 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loading duet washer stops at the rinse/spin cycle door then locks. code F31 comes up. would this have something to do with the main board?
Hello
Error F31 in your whirlpool duet washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open has a code 22
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer with an F-22 code
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed. The following link explains how to troubleshoot and repair:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
There is a tech sheet located inside the washer behind the lower kick panel under the door. Refer to your tech sheet for more detailed information concerned connector plug numbering and troubleshooting of the CCU.
If you still have questions, please let me know. I hope this helps you.
Jul 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Older whirlpool duet washer has error F11
F11 is a serial communication error between the central control unit and the motor control unit.
Unplug the machine and open the panels.
Unplug and re-plug all wire connectors from the ccu to the mcu.
Inspect all wires and harnesses for a bad wire.
Could be bad components; ccu or mcu or motor
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
