Question about Motorola Mobility H700 Wireless Headset
I have a motorolla h700 and need to remove or get the access code to put it on my new phone
    Problem Solver:
  • 18 Answers
Code is 0000
Posted on Sep 28, 2009
HOW DO I PAIR MY MOTOROLLA H700 TO MY IPHONE
The H700 is a little picky when pairing.
Make sure the H700 is fully charged.
1. Leave the H700 Microphone closed and hold down the button until it turns purple. 2. Once the light is purple, open the microphone. (If it turns blue then start over. This is normal operation mode not pairing.) 3. Go into iPhone Settings>General>Bluetooth and turn Bluetooth on 4. H700 should appear on the screen. Select it. 5. If the device asks for the Device PIN, enter: "0000" 6. The two are now paired.
The H700 may leave pairing mode during the process. This is the pickiness I mentioned. If it does then just restart the process. It may take several tries or it may work on the first shot. Just be patient.
May 03, 2011 | Video Game Consoles & Games
Motorolla headset h700 pair with blackbery
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 06, 2009 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
Unlocking phone
enter 1234 if phone lock code asks . This is the phone lock code for motorolla c168
Dec 12, 2008 | Motorola Mobility C168 Cellular Phone
My LG Shine KE970 can not find Motorolla H700 bluetooth headset
Is the question really, is your H700 in pair mode? To set this you need to push and hold the big talk button while the boom is closed. once the purple light comes on open the boom to keep the light. Now you can search for it with your cell phone.
Hope this helps and don't forget to rate :)
Dec 10, 2008 | LG Shine KE970 Cellular Phone
Forgot password for Motorolla H700
i did the 000 that didnt work and then i did the 0000 it worked so keep trying
Jul 29, 2008 | Motorola Mobility H700 Headset
Bluetooth headset
Have you ever successfully paired any bluetooth device to the L7c before. I ask this to help narrow the problem...could be a whole lot of things but more info will help me help you.
Aug 26, 2007 | Motorola Mobility H700 Wireless Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
85 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
