Question about Maytag Neptune MAH5500B Front Load Washer
Will not stop filling runs on to the floor - Maytag Neptune MAH5500B Front Load Washer
    President:
  • 1,776 Answers
This is caused by a faulty water level switch. It's a diaphragm type device consisting of a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water. Check the plastic tube for any damage and obstruction in the tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity, A lack of continuity will indicate a bad switch. Remember to unplug the machine before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 27, 2009
My Kenmore Washer 110.92597200 will not stop filling which causes water to overflow drum onto floor. It does not seem to respond to Water Level setting.
top loader machines have a small tube running up to the sensor that fills with water and affects the level settings
check that it is not a problem with the inlet solenoid not shutting of the water
call a service technician
Nov 27, 2017 | Kenmore Washing Machines
How many liters of 80/90 weight gear oil does my 1990 chevy c1500 take in the transmission?
Fill at side fill hole until fluid begins to run back out. Let it run until it stops, install plug and wipe up excess. If fully drained, usually holds less than 3 liters.
Sep 02, 2015 | 1994 Chevrolet C1500
My washer want stop filling up and when I should the machine off the water runs in the floor
Good Afternoon Friend,
I understand that your Frigidaire washer, model# FWS833A, will not stop filling. I see that you shut the machine off and the water runs onto the floor. I suggest shutting the water off at the inlet. From there I would contact your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water will not stop filling your washer. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire FWS833A Top Load Washer
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
Now set at the medium level and try again. does it stop or over fill?
If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
Jul 09, 2008 | Washing Machines
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
