Question about Samsung BL103 Digital Camera
The camera takes great pictures in dark areas, but once there is light sunlight or otherwise, there are lines across the pictures and the image is not shown, why?
  • 300 Answers
Hi!
It's most likely a broken shutter cable inside the lens - happens to Samsung cameras all the time. You should be able to take videos in any conditions and pictures in low light conditions. The only way to fix this is to change the shutter unit with cable or whole lens unit. It should be expensive so I would recommend you getting a new camera, but this time not Samsung - they're pretty awful.
Sorry for the bad news!
Tom
Posted on Sep 27, 2009
Pentax optio m10 take picture and it come out with horizontal lines across the lcd screen and when i down load them the photos are the same as the image on the screen, seems a littlr clearer out of...
Hello
OK, this sounds to me like an CCD error. This is unfortunately once of the more expensive components on a camera to be repaired.
I would suggest that you take this camera to your nearest repair store, explain to them what the problem is, and let them let you know how much it will cost to replace the CCD.
Hope this cam be of help.
Kind regards
Andrea
Aug 30, 2010 | Pentax Optio M10 Digital Camera
GE A730 lines across the screen in lit areas?
shutter unit of the lens is bad,so replace the broken,take it to camera tec.
Mar 08, 2010 | GE A730 Digital Camera
Lines on pictures that are taken in lighted areas
CCD Problem !
GO to Nikon just call them they will do it FREE as far as i know all are doing it , manufac fault see link below
RATE ME WELL
BAD CCD PROBLEM
May 03, 2009 | Nikon Coolpix 3200 Digital Camera
Horizontal lines in picture
my friend CCD imager is going bad !
u have to contact GE they will do it free of cost even if ur not in warranty bcoz it is considered a manufacturing fault by all manufacturers BAD CCD is a big problem these days
actually if the pics are discolored have pink and blue shades or puple and differentt skin tones then my friend ur CCD imager is going bad
u can contact sony they might do it free of charge bcoz it is a big problem in thousands of camera models and all are repairing free of cost as it is considered a manufac fault pls contact SONY in ur area and they will do the rest insist on free repairs and tell them abt bad ccd
see this
http://www.imaging-resource.com/badccds.html
Pls rate me FIXYA for help
Apr 03, 2009 | GE A730 Digital Camera
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Lines
hi peter,
Video will not be able to display the dark lines becoz its samling rate is low and so it cannot display detailed image.
With your 6 MP camera , the reason for the images having dark lines is that,
The SENSOR present inside your digital camera may have been covered by dirt or it may have some lines over it. so it is obvious for the images to reflect that.
So i suggest you to check the sensor with your service center.
Else you can refer to this website for more support www.samsungcamera.com/customer/faq/cus_faq_list.asp
Hope this works...
Thanx peter.
Sep 20, 2008 | Samsung Digimax S600 Digital Camera
Lines on the screen
pls try to chek if lense r working perfectly
May 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Dark images
probably the flash system got broken, or the lens got damaged. and doesn´t mesure the light
Jan 21, 2007 | Samsung Digimax 301 Digital Camera
Samsung BL103 Digital Camera Logo
315 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
