I AM UNABLE TO TRACE A SHOP THAT I CAN PURCHASE PAPER,AND INK CARTRIDGE FOR MY C330
5 Suggested Answers
SOURCE: paper detection and new ink cartridge
Press the green diamond key on the face of the printer when the error message comes up and it will print
Posted on Feb 18, 2008
Inky
  • 691 Answers
SOURCE: I have just finished replacing
If you have used a compatible cart, did you remove the tape from the vent hole?
If you have a genuine cart and feel sure the cart is not faulty them read my previous posts on intensive head cleaning.
http://www.fixya.com/support/t138226-printer_not_printing
If the head cleaning has little or no effect then you may need this following rescue kit to resolve a know problem with many of the CX range:
http://www.tradebit.com/filedetail.php/1594393-Documents-eBooks-Technical
Posted on Jun 30, 2008
  • 65 Answers
SOURCE: Problem with ink coming out on paper
Replace the toner cartridge with a brand new one. There's no such thing as refilling toner cartridges. When it's empty, the drum unit is finished and it should be replaced, not refilled. Remember that the drum unit is sensitive to light, and will also be damaged if exposed to a great amount of light over a perid.
If a new cartridge does not solve your problem, remove the cartridge and check out the charge roller. It's located in the upper part of the "cartridge-room". It's a grey roller. lower the front cover the get easy access to it.
If it looks nice and clean, just leave it. If it is dirty and smutsy, you should remove it and try to clean it with hot water. If it is damaged in any way, it should be replaced.
Still problems ?
Check out the fixing unit. Remove the fixing unit and look at the the big rollers that put out the paper. If they look nice, put the fixing unit back in. If they are burned and dirty, replace the fixing unit.
Good Luck.
Posted on Jul 29, 2009
canontech
  • 1219 Answers
SOURCE: No blus ink makes it to paper even though there is
Hi, remove ink tanks, remove print head and on piece of fabric spill some alcohol and few times press the bottom of printhead. Repet steps few time on clean fabrics.
Put it all back in and run head cleaning and then try to print nozlle check.
Posted on Sep 23, 2010
Want to buy cartridge + paper for DPP - FP95. Tell me where
The most common places for Office Max and Office Deport and Staples. Online ink and paper just Google:
purchase ink cartridges online
and you will get a LARGE LISTING
Feb 24, 2015 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Can't keep the yellow ink flowing - stops printing shortly after cleaning. I have cleaned it 5-6 times. Prints yellow right after cleaning then color fades out half way through first page.
Hi! Ok, Is you cartridge refilled? if yes then your yellow tank in the cartridge is maybe out. You can try this: Take a paper napkin and lightly and slowly touch the cartridge head where the color come out. If your cartridge is ok you should see some trace on the napkin. Try this a few time and your ink should be more and more be visible on the napkin.
If no trace then you have a problem with the cartridge head.
I hope it helped to you. Any question post me a message on adzicc@yahoo.com
Dec 07, 2010 | Brother MFC 6490CW InkJet Printer
I installed new ink and printer shows clear paper jam does not appear to have paper jam
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Oct 22, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
No blus ink makes it to paper even though there is ink in cartridge. When looking at nozle check, no trace of blue.
Sep 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
How to refill ink in hp blck cartridge
  • Purchase an ink refill kit at an office supply store. (Staples, Walmart, and Costco all carry this inexpensive kit. It usually costs about half the price of an average printer cartridge.)
  • Gather your kit, a roll of paper towels, and some clear scotch tape together on a large flat working surface, a table or desk.
  • 3Remove the empty cartridge from your printer. (Remember to close your printer lid or door while you are working.)
  • 4Cover your hands with a pair of disposable plastic gloves while you work with the messy ink.
  • 5Take a paper towel and fold it in half twice. Work over the paper towel to catch any leaking ink.
  • 6Place the empty cartridge on it.
  • 7Read the instruction manual included with the refill kit to learn how to refill your particular type of cartridge. (The following instructions are just a general guide).
  • 8Locate the fill holes on the top of the cartridge. The depressions can be felt by rubbing your finger across the label.
  • 9Use a sharp pencil to pierce the refill holes in the top of the ink cartridge. (Correct places can also be found in the kit instructions).
  • 10In addition to black, there are three colors of ink: magenta, cyan, and yellow. Follow the kit instructions on which hole to insert each color OR push a toothpick into the holes to identify the colours as markings on the printer cartridge are sometimes there to fool you into putting the wrong colours into the cartridge ink chambers.
  • 11Insert the long needle on the refill ink bottle into the correct hole.
  • 12Slowly, add the ink. Carefully watch to be sure that you do not over-fill.
  • 13Stop quickly as soon as you see a bit of ink oozing out of the hole. Without letting go of the bottle, slowly release the air, sucking a little ink back out of the ink cartridge, before you remove the needle completely.
  • 14Carefully daub the cartridge contacts on the paper towel, you should see a splotch of the ink leaking out onto the paper towel.
  • 15Cover the hole with a small piece of clear scotch tape. (This works better than the seal dots included in the kit.) Make sure that no ink is leaking out of the top holes. (That's where the clear tape comes in handy.) Be careful not to cross contaminate the colors.
  • 16Repeat steps 11-15 for each ink color.
  • 17After you have refilled all three colors, carefully blot (don't wipe or rub) the cartridge printhead on a folded piece of paper towel. You may need to do this several times. Do this until it stops bleeding and you see an even stripe of three colors showing up on the towel.
  • 18If the blot shows the colors either faded or not at all, blot on wet paper towel and again on dry, to get the ink flowing.
  • 19Replace the ink cartridge into the printer. Never, ever install a leaking print cartridge.
  • 20Immediately print something, anything, just to get the ink flowing. Print several test pages, preferable photos with a lot of different colors.
  • 21Follow the cleaning or priming cycles for your specific printer.
  • May 25, 2010 | Office Equipment & Supplies
    I would like to purchase the ink cartridge for my HP2225A
    the shop you bought the printer from may sell them otherwise go to your local stationers - Staples, Officeworld, Cartridge World etc.
    Nov 04, 2009 | Computers & Internet
    My printer is saying unable to print
    Try one or more of these solutions:
    • Press the fontp.gif power button to make sure that the printer is on.
    • Turn off the printer and make sure that the power cord is securely plugged in.
    • Make sure that your outlet works and is not controlled by a wall switch or timer
    Lights came on and then went out
    The printer's voltage may not match the outlet rating. Turn off the printer and unplug it immediately. Then, check the printer labels.
    If the voltage does not match, DO NOT PLUG YOUR PRINTER BACK IN. Contact your dealer.
    Only the power light is on
    • Turn off the printer and computer. Make sure that the printer's interface cable is securely plugged in.
    • Make sure that there is no packing material in the printer.
    • Turn off the printer and the computer and disconnect the printer's interface cable. Then, print an operation check page. See Running a printer operation check.
    If the check page prints correctly, make sure that the printer software and your application are installed correctly.
    • If you are trying to print a large image, your computer may not have enough memory to print. Try printing a smaller image.
    • Windows Me and 98 users can clear any stalled print jobs from the Spool Manager. For instructions, see Using EPSON Spool Manager.
    • If the printer sounds like it is trying to print, but is unable to, run the Head Cleaning utility.
    Paper out light is flashing or on Check EPSON Status Monitor 3 (for Windows) or EPSON StatusMonitor (for Macintosh) to find the cause of the error, then try one or more of these solutions:
    • If the fontm1.gif paper out light is on and there is no paper in the printer, load paper into the sheet feeder.
    • If the fonth.gif ink out light is flashing, a low supply of ink is indicated. Obtain a replacement cartridge of the appropriate type. To determine which cartridge requires replacement, see Replacing an Empty Ink Cartridge.
    • If the fonth.gif ink out light is on and the ink cartridge is empty, replace the appropriate ink cartridge. To determine which ink cartridge is empty, see Replacing an Empty Ink Cartridge.
    Error light is on and power light is flashing
    Follow the steps below.
    r_1.gif Press the fontm1.gif paper button, then remove any paper from the printer. r_2.gif Turn the printer off. Check for and remove any foreign objects or pieces of paper from inside the printer. Also, make sure that there is sufficient space around the vent on the back of the printer to allow proper ventilation. Remove any objects blocking the vent. Then, turn the printer back on
    May 27, 2009 | Brother MFC-210C All-In-One Printer
    Paper detection and new ink cartridge
    Dec 05, 2007 | Office Equipment & Supplies
    12 people viewed this question
    jasbo
    jasbo
