Question about InFocus LP70+ Multimedia Projector
Over Heating I just bought I new bulb installed it with care now, it still over heats last time the bulb light would blink now with the new one it just shuts off and its hot than a sum in a B***** if ya feel me I hear fans runnin any sugestions
  • CCORE Mar 12, 2008
    I have the same issue. I was trying to see why I had a shadow. I took out the bulb and re-installed it with the same results.
  • Anonymous May 11, 2008
    I had the same problem. Put a house fan on the right side and it ran fine for hours. I think one of the fans may have been stuck. Since then, runs fine.
    Tim
If thats the problem buy a new projector :)
Posted on May 01, 2008
Mitsubishi tv model 73638. new bulb works for a min then shuts off and has flashing yellow light
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 28, 2014 | NEC T.v. Wall Mount
72MX195 won't turn on blinks 16 times
The power supply may have failed.
Oct 30, 2013 | Toshiba 72MX195 72" HDTV
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
Mar 15, 2013 | Sony KDF-E60A20 60 in. LCD HDTV
My VPL-VW50 suddenly stopped working a couple months ago. It turned on, the fans started, then it would stop and a red light began blinking three times. I looked up the code and found that it needed a new...
fisrt, did you reset the lamp timer? if the projector turns on again, go into the menu settings and reset the lamp timer. 3 flashes also mean that the lamp is too hot. let the projector go through it's cooldown mode and shutdown before you unplug it. remove the filter case and vacuum or blow the dust out of the filter. you can also blow the dust out of the projector (if any) with canned air. lastly, be careful where you buy lamps from. you get what you pay for. cheaper isn't always better.
Dec 08, 2009 | Sony VPL-VW50 Projector
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi,bought new bulb and installed but red light still blinks
Make sure new lamp is installed properly in its position and lamp cover is placed back securely.
If still red light is blinking, let me know is it Lamp light or Standby light that is blinking and how many times it blinks
Thanks.
Oct 07, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kdf60655 green light blinking 37 times and pic goes off/on
I am having the same problem and we purchased the tv new in April of 2005 had the four yr warranty also. That's obviously passed and now we don't know what to do? What did you find out?
May 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung S5687 w/hl shuts off after 20 seconds
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 29, 2017 | Samsung DLP HL-P5663W 56" TV
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
85 people viewed this question
Top InFocus Office Equipment & Supplies Experts
neOen
Level 1 Expert
Jaime Hernandez
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
