Question about Intel Computers & Internet
Where are the 4 slots for the memory cards - Intel Computers & Internet
  • 43 Answers
Not all motherboards have 4 slots, and if yours does, it does not hold memory cards it holds RAM.
Posted on Sep 27, 2009
    Guru:
  • 441 Answers
For a PC: Open the case. In mainly the middle part of the motherboard you will see a fan that is connected to a heatsink. This is the CPU. Normally the RAM slots will be to the right of the CPU.
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Do all compaq presario cq60 have a memory slot?
It has a memory card slot (left-side towards the front), but your particular memory card might be too big for the slot. There are several different variations of memory cards out now. Of course the newer the variation, the smaller that card is. This laptop is fairly new so it might not be compatible with your memory card. Does your camera have a USB cable for transferring pictures? If so, then just use that.
Mar 13, 2010 | Compaq Presario CQ60-220US PC Laptop
My memory card slot 1(PS2) does not read cards but slot 2 does?
take out slot one memory card and insert your second memory card into it (they are supposed to use slot 1)
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
PS2 STATES THAT MEMORY CARD IS NOT IN SLOT, BUT IT IS.
THis is simple. Either your memory card has not enough room, the memory card is broken or the slot you are putting it in is broken. Try putting it in the other slot.
May 24, 2009 | THQ Video Game Consoles & Games
I put a game cube game in to the wii and it says to insert a memory card into slot A so i put a 128mb memory card into slot A andi turn the wii on and it says no memory card found in slot A WHY?
It might be talking about the GameCube memory card slots, not the SD card slots. There should be a door on the top/left side of the WII. See if it's talking abou that.
Aug 18, 2008 | Nintendo Wii Console
Memory Card Slot Problem
Well, this problem may appear due to your memory slot is dirty. Try this simple solution first:
  • Off your phone (IMPORTANT!)
  • Open your phone back case
  • Find the memory card slot
  • Clean the slot (gold stripes) with a rubber eraser
  • Clean the messy
Should work by now.
Jan 08, 2008 | Nokia 6680 Handheld
PS2 doesn't acknowledge memory card in memory card slot 1
make sure that theres nothing blocking the mem slot 1.
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
