When a dvd is placed in the player it says no disc
    Problem Solver:
  • 9 Answers
Need to clean the eye, disc cleaner would help ya
Posted on Sep 27, 2009
Venturer dvd player PVS1262 says no disc
Is this a multi region player? If it is, it might be that it doesn't recognize
the region your DVD is associated with.
Jul 06, 2014 | Apex Digital AD-5131 DVD Player
Can you manually release a DVD from the Panasonic S32? The DVD player 'died' - with a CD inside. The instructions are silent on a manual solution.
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!!
Apr 01, 2010 | Panasonic Televison & Video
CD/DVD drawer won't open so CD stuck inside :(
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Dvd is stuck
Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
  • Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
  • Never work on an electrical device that's still plugged in.
  • Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
  • Follow these steps to remove it
    Step 1 Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Step 2 Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Step 3 Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
  • Step 4 Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
  • Step 5 Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
  • Step 6 Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
  • Oct 10, 2009 | iLO DVDR05 DVD Recorder
    I am unable to eject a DVD disk from the player either with the remote or player mounted buttons. Your advice would be appreciated.
    do this with the unit off:1Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
    Step2Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place. Step3Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases. Step4Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet. Step5Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center. Step6Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
    if this helps dont forget to leave a fixya rating as thats how we get paid
    Apr 25, 2009 | Toshiba SD-K220S DVD/CD Player w/Built-in...
    DMR ES15 computer burnt dvd will not read
    Place the disc back in the computer, open the program that burned the disk and finalize the disc, once finalized it should work in any dvr
    Feb 16, 2009 | Panasonic DMRES15 DVD Recorder
    Phillips pet 706/05 dvd player wont dvd-r-rw
    • Disc not loaded. Load a disc into the player, close the door and press PLAY.
    • The disc used may be defective. The disc used may be defective, try another disc.
    • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
    • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
    • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
      The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
    Jul 18, 2008 | Philips Televison & Video
    DVD Player won't open
    Try this. This works on some brands and models.
    Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
    Jun 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
    Televison & Video Logo
    16 people viewed this question
    Top Televison & Video Experts
