What size wall mount bolts for Toshiba 32'' LCD TV 32AV615DB. Thanks
ward_knutson
  • 64 Answers
SOURCE: Want to wall mount tv but don't don't were to bolt.
I have my 32" Protron mounted on my wall. There are six holes on the back of the set that you attach the mount. I cant find any links to pictures but it should be pretty straight forward. You should be able to use any generic LCD wall mount, just make sure it can hold an 32" since I made the mistake thinking all wall mounts were the same. I purchased mine at Best Buy but you should be able to find a mount anywhere. You will need to fasten the mount onto the studs in your wall. Drywall by itself will not be sufficient and cannot support the weight of the TV.
The wall mount should come with everything you need, e.g., screws, brackets, etc., with the exception of the tools. FYI... it's not going to be an easy job so be patient and take your time. It's probably going to take the good portion of a day. Also, as for the holes on the back, just be careful when performing the final mount to make sure it doesn't fall. It would be wise to have someone help you.
Posted on Nov 25, 2008
  • 146 Answers
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Posted on Jan 30, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
budmrtn
  • 11361 Answers
SOURCE: bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 05, 2010
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Posted on Jan 30, 2011
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
How much does this TV weigh? Is it considered a 32" when mounting on wall or do you considered the entire diagonal at 38"?
The TDA-03211c weighs 39.5 pounds; however, I'm not sure if that is with or without the base. The shipping weight of the TV is 50.3 pounds. Most wall mounts use the standard screen diagonal measurement to determine what size TV it will support. So the 32" is sufficient information for choosing a wall mount.
I hope this helps.
Nov 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
Bolt size
Jul 04, 2010 | Sylvania LC-321SS9 32 in. LCD TV
Screw size to bolt panasonic 32 inch lcd into
Dec 23, 2009 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
ILO 32" LCD
yes it is mountable. the 4 bolts are metric size is 6mm -1.0 x 40 mm
Use are large tv wall mount unit and buy the bolts seperately. I just hung mine and the
only problem I am having is I cannot remove the table top mount off the bottom of my TV
Can you halp??
Mar 29, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
613 people viewed this question
Top Televison & Video Experts
