Question about Haier Heating & Cooling
Blower fan stays on while the unit is off - Haier Heating & Cooling
    Problem Solver:
  • 14 Answers
Make sure you have the fan switch on auto in the thermostat
Posted on Sep 28, 2009
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
Feb 23, 2015 | Nissan Cars & Trucks
My blower motor wont turn off in my furnance?
check the fan setting on your thermostat. On means always on, auto/int means only comes on during heating/cooling. if the thermostat is set to auto / int and the fan keeps running? you may have a bad fan relay switch. It may be integral on the primary control board of your unit.
Sep 04, 2014 | Heating & Cooling
What will stop the fan to stop spinning on a goodman ac unit on the outside
If you are wanting to just get it to cut off because it won't do it on it's own, you can turn the a/c breaker off at the breaker box. I have seen alot of blower fan switches go out on older goodman units and the blower stays running all of the time. Get a technician to check it for you. Good luck .
Jun 18, 2011 | Heating & Cooling
I have a Volvo 2004 S80 whose blower fan motor stays on, even after the ignition switch has been turned off. What gives? Is this a normal function or should it go off like everything else when you shut it...
Not True. I have a 2004 S60 and a std features is that the blower motor will run from 10 minutes to an hour after the engine has been turned off, This is to dry the evaporator in the dash and avoid musty odors.
If it drains your battery dead there are possible issues; 1) a weak battery that needs replacing or 2) a faulty power stage/transistor unit ont he blower fan.
The transistor unit has power and ground and a digital signal from the control unit. When the transistor sticks, the the blower will not stop when the ignition is turned off.
Apr 23, 2011 | 2004 Volvo S80
Frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Apr 24, 2010 | Frigidaire FAC126P1 wall/window Air...
My Rheem central A/C blower motor cycles on & off
Depending on age of Rheem they have a time delay relay. May be causing the problem. The time delay operates the fan. Try turning fan to continuous and see if it stays on.
Jun 07, 2009 | Heating & Cooling
Ac fan stays on high
If you shut off unit and fan still runs, I had the same problem. I needed to replace blower motor resister located behind glove box. 2 plugs and 2 screws to remove. bought off internet for $60.
May 20, 2009 | 2003 Chrysler Town & Country
Air conditioning blower stays on at all times.
Per your description, I believe you may have a blower fan relay that is stuck closed.
Remove the relay from the under-hood fuse center and see if the fan stops.
If it does stop, put the relay in slowly and see if you here the relay "click" and the fan come back on.
Let me know.
Regards,
May 07, 2009 | 2003 GMC Sierra
BLOWER PROBLEM
What do you mean by "blower"? Is it the radiator fan or the fan inside the cabin that is for heating and ventilation?
Scott
Oct 22, 2008 | 2003 BMW 5 Series
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
