Question about Jenn-Air JFC2087HRS Side by Side Refrigerator
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is running into the fridge to fill up something, but actually the water ends up on the floor. It also appears to come from this back tube.
  • Jenn-Air Master
  • 4,655 Answers
The only solution for this is to replace all the tubing that comes from the water control valve. Sounds to me that you also have a leak in the ice maker tubing. Sea Breeze
Posted on Sep 27, 2009
  • 4,070 Answers
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
4 Suggested Answers
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
  • 103 Answers
SOURCE: Jenn Air fridge water dispensor stopped working
Hi: You press the switch and it makes a faint humming noise. That tells me the switch on the front panel is ok. The switch for the ice and water is actually on the bottom of the ref. The internal system of the ref is not under city water pressure. Ice is made so that's ok. There is a solenoid where the water attaches to the fridge down below which can fail. Just for giggles try tapping the switch with the plastic handle of a screwdriver. To loosen any scale that might have built up. As I'm unemployed also I'm giving you that trick. Otherwise I would just say replace it. I hope this helps, Jeff
Posted on Jun 09, 2009
Water is leaking under fridge when I use the water dispenser
This means you have a cracked water line tube coming from the valve. The water valve will be in the rear near the compressor, likely made of blue plastic. If the fridge has an icemaker, there will be two fill tubes coming off of the valve, the water dispenser line will be the larger of the two... depending on the model, there will be a quick disconnect behind the kickplate below the freezer door, disconnect the water line there and replace that section back to the valve... Water Line 5210JA3004U
Jul 18, 2016 | Refrigerators
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Frozen potatoes and soft butter, fridge not working
Anytime one of the cooling tubes is blocked it forces the cold air from the freezer through the open cooling tube or tubes so you will have spot freeze ups. Suggest you use a flexible wire like a guitar string to attemp to clear the blockage. If you heat the wire with a hair dryer, it will make the job faster.
As far as the unit resetting itself, it could be a preset condition. If the sensor are telling the control board one thing and you are trying to change settings, then the preset conditions could be over riding your commands. Get the cooling tubes cleared and see if things go back to normal.
The water dispenser - could be you have a leak in the water line running into the door or it could be the water depenser itself. Not enough data to tell - suggest you localize the leak. Sometimes flour will tell you where the leak starts.
Jan 08, 2012 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
GE GSS22JFMC when I press the water button it leaks
That's where the water line runs to get to the dispenser. You may have to remove the cardboard backing to see it. The line runs from the water inlet valve. That's where the supply line from the house connects to the fridge. One line goes up to the ice maker and the other goes over to the fridge side where it goes inside the fridge behind the crisper to a reservoir where the water is chilled before it goes to the dispenser. Look for the water coming out when someone else tries the dispenser. Look for a fitting that has come loose.
Oct 02, 2009 | Refrigerators
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Jan 27, 2008 | Refrigerators
Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Jenn-Air JFC2087HRS Side by Side Refrigerator Logo
324 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
