Question about Mitsubishi VS-50111 50" Rear Projection Television
2002 Mitsubishi VS-50111 Won't stay on
The information that I have received thus far indicates that the 22 error code indicates the trouble is with the Convergence IC. What is the component part number that I need to buy for the replacements? Can I get it at a local store like Radio Shack & what specifically do I ask for?
  • Anonymous Dec 17, 2008
    where would you find the 'convergence IC' in the back of the tv or how would I get a manual of for vs50111 to locate it?
My television the power will come on but it won't show now picture and it will cut right back offf. I think it is the fuse but I just don't know where the fuse go. Because on the back of my television their are alot of fuses but I don't know which one it is.
Posted on Oct 25, 2008
    Genius:
  • 1,153 Answers
No you will need to search vancebaldwin, or Mcmelectronics, tritronics, any electronic online part store. RS does not carry it. Also there are fuses need to be changed also. More info at ctechnicians.com
Posted on Dec 18, 2007
On my vs 50111 my power button stopped working about 6 weeks ago but i used the remote however now i plu it in and the reen light comes on indicating power but then shuts off right after. it seemed to
It could be a simple loose or broken wire,so
take back off and check it.Make sure unplugged first.
Could also be plug end.I have this with our Samsung,
but push the remote two to three times and it stays on.
LUCK
Sep 25, 2014 | Mitsubishi VS-50111 50" Rear Projection...
Orange lamp light stays on
model indicated does not have a lamp or a orange light..............
Mar 24, 2012 | Mitsubishi VS-50111 50" Rear Projection...
When i turn it on it stays on for about 2 seconds and turns right back off
Model indicated is 2002 model. It should have the self check feature:
When you turn on and green light goes off: On the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and then release both buttons.
The power light should blink a error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know (comment here) what error code you see and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 09, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
How to figure out diagnostic code
wat is the code ???
is it Error code 2-3
if so check q5a01 and 03 thrue to q5a06
also replace T5a31 PN/340p216010
Jan 14, 2009 | Mitsubishi VS-50111 50" Rear Projection...
MY T.V. WONT TURN ON
this sounds like your flyback converter is burned out on the circut board....cheap part! but must be done by pro!
Dec 09, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Diagnostic code 23
Loss of horizontal deflection is what code 23 means in that model.
Mar 23, 2008 | Mitsubishi VS-50111 50" Rear Projection...
2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Dec 17, 2007 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
