I replaced my bulb recently. now i have white verticle lines trough the whole tv its samsung hl5063 w
  • 3,741 Answers
Try power off the TV (wait a bit until the lamp cool down with the fan) then unplug it for an hour. If the problem subsist the DMD board (Digital Micro Mirror) will need to be replaced.
White line are line of small mirror that are kept in a position that give white. You could still try to see if some connector or data ribbon is not well inserted before going to the repair shop.
The problem is DMD chip of your tv . The chip has millions of micro mirrors on it that reflect the light from the color wheel to the screen. If it’s not working properly, the mirrors most likely are not tipping back and forth which can cause the vertical lines.
--------------- if you want to do it manually you can get the required part at (www.radioshack.com or at www.shopjimmy.com or at www.partstore.com) -------------------- this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 27, 2009
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The tv has a 3" white verticle white line down the middle
Sounds like your LCD panel is failinf and will need to be replaced it is going to be costly around 1500
Nov 29, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Verticle line running down the screen.Thin verticle line running down the screen.
You have a defective LCD panel. The only way to fix it is to replace the whole LCD panel. It is the most expensive part in the TV (usually $500-2500) depending the make, model, and size. It is also time consuming as you need to take the whole TV apart in order to replace that part.
Oct 09, 2009 | LG Televison & Video
LG REAR PROJECTION TV DARK SCREEN PROBLEM
very possible unit has bad optical engine .May not be worth repairing.Optical engine is complete unit that includes lamp,LCD panels, fans,optics and other parts.They come complete and cost about 3-6 hundred dollars ..thanks
Jul 30, 2009 | LG 62SX4D 62" Television
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
