It is blowing out room temperture air all the fans are working correctly, no power supply problem just no cold air at all I changed the filter and looked for a reset button but no, we had a thunderstorm yesterday and the power in the house kept going in and out.
  • 89 Answers
Sounds like your compressor might have been hit by lightning. If you have 220 volts going to the outdoor unit use a stick to push the contactor in. The fan and compressor should start, if not check the capacitor. If the capacitor is good, the compressor is probably bad.
Posted on Oct 08, 2009
Bryant plus 90
try replacing the run capacitor
Sep 03, 2013 | Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
The unit runs good fan blows good filter is clean no cold air only room temp.
Check if the outdoor unit is operating, if it works put your hand to see if it works if the compressor is not changed then a capacitor if it works then he freon the machine.
Aug 10, 2011 | Heating & Cooling
I have a ruud ubhc-17j11sfd that does not blow cold air. it blows room temperature air only. the unit seems to run ok and the outside fan runs ok also. The filter is cleaned and the thermostat is set to...
Hello, if the airflow seems good and the unit is clean it is possible that the unit has a low refrigerant charge due to a leak, if you have a thermometer measure the return air and the supply air, tjen find the differance between the two, if it is below 15 then the unit is undercharged and will neec to be recharged.
Jun 15, 2011 | Ruud UBHC Air Conditioner
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
The air condition blow out cool air but stop in 3 second, low fan, the switch seen to work ok the inside switch, the freeon was put in to days ago the pump is turning but hi persure is not activating to...
need to replace the pressure sensor and fill up the gas 134 R or the filter gas is blocked , when is running the pipe are one hot and the others is cold be sure the vent fan is switch on
May 24, 2010 | 1997 Cadillac DeVille
Temperture Gage
First of all, it doesn't sound like your thermostat is working correctly to keep good hot/warm air coming , so I would change that, or have it changed for better heating inside. If you lift the hood & look in front of your radiator, On the engine side, you'll see a fan attached to, or in front of the radiator. It won't come on until the coolant temperature gauge gets up to proper operating temperature. Without getting in to too much detail, have your thermostat changed, and my guess is everything else will start working as it should, and whoever does the work, should know enough to check the fan operation when they do the thermostat.
Jan 28, 2009 | 1991 Mazda Protege
Heater not heating my Jeep
the problem is the air temperture control door (known as a blend door) is stuck or the door's actuator is not working. your engine temp is correct and not the problem.
Dec 16, 2008 | 1998 Jeep Cherokee
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
