Question about Maytag Dishwashers
Doesn't seem to fill with water. Maytag MDB6000AWW
  • jckaroly Sep 27, 2009
    I just tried the washer using the 'short' cycle and it filled with water with no proble. So perhaps it is an issue with the control?
  • 1,531 Answers
If the washer is not flooding the floor or room turn it off the pull you dain hose up from the drain tube you should here water coming out.once the water stop keep the hose up but do not pull it out of the wall and restart the washer it should then fill up to the proper level and then start washing. i hope this helps please let me know
Posted on Sep 27, 2009
Washing machine doesn't fill with hot or clod water.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 05, 2011 | Maytag Washing Machines
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
My Maytag MDB6000AWW is leaving a heavy white film. Mostly on the cups and the dishes in on outside, although this may not be relevant. The arms on the top and bottom are clear and seem to be spinning,...
Yes,
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 15, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Heating element will not shut off
Check thermostat. If it is Ok check other parts that triggers heater circuit.
Apr 05, 2010 | Maytag MDB6000 Dishwasher
We have a MDB6000AWW model d/w. It is leaking
Yes what happens is it gets past the rubber seal somewhere higher during the cycle and gravity pulls the water down to where you see it leaking. 11 years is a good lifespan of a door seal. Plus they are easy to pull out and replace. Just yank it out and push the new one in. Hope this helps.
Jan 25, 2010 | Maytag MDB6000 Dishwasher
Fills up the first tim but not after for the rest of the cycle.
it sounds like the fill float could be stuck in the full position and sticks during the rinse cycle check the float it is in the front to the left or right it looks like a bell, move it up and down and if necessary remove the front kick plate(s) and observe the mechanism as you move it up and down to ensure it is not hanging up.
Sep 11, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Dishwashers Logo
114 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
