Question about Sony STR-DG510 Receiver
No Audio I have DirecTV and a Sony BDP-300 Blu-ray Player connected to the receiver. I get surround sound from the satellite receiver, but none from the Blu-Ray player. Both are connected with HDMI and optical audio cables. I get pass-thru audio from the Blu-Ray player to the Samsung HDTV.
  • DickJohnson Jan 28, 2008
    Thanks, I believe you are absolutely correct. I am currently using the digital coax and it does work. The HDMI is plugged to the DVD.
  • Anonymous Mar 15, 2014
    Oppo Blu-ray player (tried 2 different ones) changed HDMI cables, switched inputs on the Marantz receiver. Nothing helped.
  • 3 Answers
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Posted on Jan 27, 2008
2 Suggested Answers
  • 1067 Answers
SOURCE: No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Posted on Jan 20, 2008
Sony bdp-bx57 signal cuts out
test the connection see the diagram attached. Clean the contacts and connector with contacts cleaner.180f246a-cc1f-493b-9d8e-3abff472975f.jpega07d2d96-4cdd-4858-8bc3-356bb92dae0b.gif
However you can restore in the menu to factory default.and see what happen.
Jul 13, 2013 | Sony BDP-BX57 Blu-Ray Player
No Audio
Jan 20, 2008 | Sony STR-DG510 Receiver
I just bought the sony blu ray and cannot hook it up correctly to the surround sound, dish network and tv. The instructions given from Sony and Philips did not work.
Hi my name is Mike Houston of DISH Network, I see you aretrying to connect your Blu-ray to the surround sound system and you have DISHNetwork. I wanted to get a little more detail about the equipment to betterassist you, I was looking for the model numbers for the Sony and Philipsequipment to look at the configuration as well did you want any of the componentsconnected to the DISH receiver. I will leave you my e-mail to get the componentmodel numbers and will you be connecting it to our DISH equipment.
Oct 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
May 16, 2011 | Sony BDP-S350 Blu-Ray Player
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Oct 15, 2008 | Sony DAV-S500 System
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Sony STR-DG510 Receiver Logo
433 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
