Question about Dryers
No start my dryer whirlpool model ler7646jq0 no start
  • 67 Answers
Try a new door switch
Posted on Sep 29, 2009
  • 986 Answers
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Posted on Sep 27, 2009
Hello, I have whirlpool dryer model # LER7646JQ0. My dryer works great with one exception, it has no heat. I checked the heating element and all of the coils are intact. I then replaced the thermostat and...
Hello avonladywend,
After reading your post I can't help but wonder, have you checked to insure the dryer has 240vac going to it. These dryer's will appear to work almost perfectly with 120vac, with one exception...you guessed it, No Heat !
If you know the location of your homes service panel go to it. Locate the 30amp breaker and turn it all the way "off" and then all the way "on" do not just identify it and assume it is ok because ot doesn't appear "tripped".
This happens all to often when I go to a customers home. The first words out of there mouths is "It's not the breaker I checked" and then I physically check "reset" the breaker ( after verifying the dryer is only receiving 120vac and not 240vac with my meter ) and what do you know, heat !
That could be the problem all it's own. The other thing to look for is a poor connection ( loose and burnt or badly oxidized...or both ) on either of the "hot" cord lines coming into the unit, either the red or black.
Let me know what you find out, but that's where I'd be looking before installing anymore part's.
good luck.
macmarkus :)
May 01, 2010 | Whirlpool Dryers
Thinking of getting either a Wpl LER7646jQ0 or Kenmore
I'll give it to you straight
Get the Kenmore. i work on all of them and i work on less kenmore
Jan 06, 2010 | Whirlpool Dryers
Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Oct 18, 2009 | Whirlpool LER4634J Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
WHIRLPOOL DRYER STPS SPINNING AFTER A FEW MIN OF USE.
I would check the belt and the motor. The temp gauge has to do with the heating of the system. You can locate both of those at the back of the unit
Feb 11, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer Help
Hi theres 2 things that can cause this #1 a dirty vent to the outside. #2 a dirty lint filer , Take the lint filter out & run hot water through it. If water wont flow through the screen, Its gummed up by Bounce sheet residue, Clean the filter . It should be ok
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Ghost in my dryer????
Here are a few ideas of what might be wrong.. based on your description.. You've bypassed the thermal fuse and the dryer worked however once you removed the bypass, did it work after that? based on your symptom.. it appears that one of the auto-ressting 'overtemp snap switches' may be your problem and may be shutting your system down because it is tripping from excessive heat or it is prematurely tripping because it is defective. I've included a website link that shows assembly drawings and parts breakdown for you to examine but I suspect that you have a bad overtemp switch.. ( I assume that you've cleaned out all lint etc from the vent system both inside and outside the dryer) If you haven't... then you may not get adequate air flow and you truly are getting an overtemp condition.. Good luck.. Here is the link http://www.pcappliancerepair.com/model-display.php
Hope this helps !
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
161 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
