Question about Kodak EASYSHARE Printer Dock Thermal Photo
I can"t get the ink cartridge out .I have pushed the green button up and it wont budge. I have done this many many times. roepng@yahoo.com
2 Suggested Answers
SOURCE: replaced the cartridges now red lite on wont print
Try unplugging and then plug back in
Posted on Apr 24, 2010
How do I install the ink cartridge
You will find two buttons on your printer.
One for power and the another is a function button.
Push them together at the same time while the printer is on.
In most cases this will move the ink head to the center on the machine in order for you to remove the old ink cartridges and install the new ones. However a different button may need to be used consult the manual in this regard.
The ink cartridges are clipped in, you will need to undo the clip!
Then pull the ink cartridge out, usually upward force applies.
Now once the old cartridges are removed you can install the new cartridges.
Be sure to remove any stickers that are meant to be removed, read the sticker and if it says "remove before use" then remove it.
Insert the cartridge and push them down, then the clip is to be clipped in.
Now to get the ink head to move back to it's lair first try pushing the function button.
If nothing happens then push both buttons together again.
Please read this session a number of times to get the jist of what needs to be done.
Also I would like to ask you to please rate this session with the use of the Thumbs on the right.
Thanking you very much.
Till next time!
damnor01
Mar 20, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Resetter
http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing thisreset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′. This method takes from indoreset yahoo group and prepared by Choy.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
http://downloadprinterresetter.blogspot.com/
OK, go to website above, and download a "Resetting" tool, this makes resetting easier to do.
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
HI, IS THEIR AN OVER RIDE FUNCTION IF ONE OF MY BLACK INK CARTRIDGES IS EMPTY THAT WILL ALLOW ME TO STILL PRINT UNTIL I GET A REPLACEMENT CARTRIDGE.
on some printer if there is more than one color and one cartrige is empty you can push a little green button with a check mark on it.or ok button.you just won't be able to print any thing that uses that color..example==if you try to print a document and it says that a color is empty push the okay button on the printer.if you got anymore qeustions email me at gamecrazy944@yahoo.com
Jun 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMAR MP150 E5 problem
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-28
Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How to Override Ink Level Gauge When Using Refilled Cartridges
hi,
604
Oct 08, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Kodak EASYSHARE Printer Dock Thermal Photo Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
