Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
The motor is still running but has lost connnection with the trimmer because it no longer turns.
Black&decker electric corded weed eater not running at full speed
the thickness of the cord , the length of the cord will both affect the speed of the motor as it needs extra power to run the longer length or thicker cord
most trimmer motors use a bush at the end of the armature shaft and this is affected by the sap out of the grass and dries out
this causes excessive wear which allows the armature to touch the field winding shoes and "pole "out . This intereference slows down the speed of the machine as it is a short in the field current to the armature
If you have an accredited appliance repair shop that is good with trimmers they may be able to replace the bushes but generally it is a replacement trimmer as the fix
have it checked out anyway.
Sep 16, 2015 | Garden
Trimmer runs but will not cut?
Is this gas or electric?
Sometimes if the trimmer cord is too long, the engine does not have enough power to spin it fast enough to allow it to cut.
Mar 19, 2015 | Garden
Trimmer line is spinning but slowly, like it has lost power.
Sounds like just what you said "it's lost power" Are you sure the battery is fully charged? Try another battery if you have one. There is no clutch to slip on this type trimmer. It's got to be either the battery is not putting out enough to turn the motor or the motor itself is bad.
Aug 23, 2014 | Black & Decker 18volt Cordless Trimmer 18v...
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
How do I fix an intelliflo vs that is offline?
turn off aqualink then turn back on then turn intelliflow on it should see it also works with heaters
Jul 02, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Carburator will run motor but will not let it stay
Most of us, at one time or another, leave fuel in trimmers or mowers for too long a time without running them. This causes the fuel to gum up and block passages, etc. A good idea is to add a fuel stabilizer (available at almost any hardware store) to the fuel or fuel/oil mix that you use for your small engines. It will allow the fuel to stay viable for a much longer period of time.
If you decide to actually diassemble your carb, and you have a digital camera, I would advise you to take picture along the way unless you are very good at remembering where things go after you have taken them apart. You also will probably find limiter caps over the setting needles. Sometimes you can simply pull them off; sometimes it is more involved than that. I would simply try spraying a carb cleaner into the carb (with the air filter removed), letting it sit for a few minutes, then try starting again.
Hope this also helps.
Oct 07, 2009 | Homelite Garden
Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
May 25, 2009 | Black & Decker Garden
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
48 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
