Question about Texas Instruments TI-83 Plus Calculator
I can't see anything on my screen. Its all random numbers and stray marks
  • Texas Instru... Master
  • 7,993 Answers
Press [2nd][QUIT] to interrupt any program stuck in memeory. Press [CLEAR] button to clear the screen.
Try adjusting the screen contrast.
Hope it helps.
Posted on Sep 27, 2009
  • k24674 Nov 06, 2009
    The behavior may be due to games installed in the calculator. Only you the owner know what is the machine. If this is due to a game hung in memory, you can remove the main batteries to force the game or program to shut down. Keep batteries out of the calculator for a while ( a few hours) then insert batteries and turn calculator back on again. You may have to adjust the contrast. To do so
    1. Press [2nd] key and release it.
    2. Press and Hold the [UPArrow]
    3. Keep Pressing until screen is dark enough.
    If that does not revive your calculator, you may have to follow the link to the TI FAQ and Knowledge Base to an article that addesses the question of a graphing calculator not turning on.
    Hope it helps.
My calculator is broken somehow, it has numbers at random places on the screen and when i type numbers in it doesnt show the entire digit, and with leave blankes and random dots all over the screen, i dont...
remove the battery and take out the panels and the pads to be cleaned .now reset the pads after cleaning to see if the fault changes, if not the calculator is faulty as it has a faulty board,.
Sep 30, 2010 | Texas Instruments TI-83 Plus Calculator
How do I program the calculator to read random numbers 1-50?
The post answer the question concerning how to generate random integers. The example given is for rolling a dice. I am inserting the modification that treats your case at the end.
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates keypresses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
To generate random number between 1 and 50
Int(Ran#×50)+1
Jul 16, 2010 | Casio FX-115ES Scientific Calculator
How do i generate random numbers on the casio fx-9860G
In the paragraph above, the bold text in square brackets indicates key presses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
Ran#×6
Int(Ran#×6)
Int(Ran#×6)+1
Jul 06, 2010 | Casio CFX-9850G Plus Calculator
I am finding tiny holes in the sleeves and fronts of random cotton shirts. i had an exterminator in and he could not find one bug in my entire house. is it possible it is washer or dryer related? it's...
Check for any small pieces of sharp metal in your washer tub on the front and back where the tub has a seam and is welded together. (you will need a flashlight and will have to put your head inside the washer to see this.) Check very carefully it could be very small. I have seen the stray metal welded into the tub and the tub would have to be replaced. Also check your dryer for anything sharp or holes in the front and back seals. Please rate this post.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Numbers/Letters just showing up on the screen
keypad mat of your might have rust or deteriorated.
does your wet?
Apr 27, 2009 | T-Mobile Dash Smartphone
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
MY E815 screen has weird signs
Check this link to see info about your phone.
Apr 25, 2008 | Motorola Mobility E815
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Texas Instruments TI-83 Plus Calculator Logo
118 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
