Question about Pentax *ist DS Digital Camera
Sometimes my pc connection to pentax camera can not access the sd card
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Sep 28, 2009
Why can't I download pictures to computer?
You can do that by two methods.
1. Memory Media
The E40 accepts SD and SDHC memory cards and has approximately 10MB of internal storage.
Insert the memory into your laptop SD card slot.
You may not need a SD Card carrier as the SD type for both Camera and laptop is same.
2. Connectivity
There is a USB/AV connector on the side of the camera as well as a dock connector on the bottom of the camera.
26041754-feum23phdkkiz3bf0e0pm1n0-4-0.png Pentax Optio E40 Review DigitalCameraReview
Jan 06, 2016 | Pentax Optio E40 Digital Camera
Pentax K20D error message Camera cant display this image. And images are wiped from memory card.
One or more of the image files are corrupted. This can happen when the camera batteries fail at an inopportune time (while a file is being saved, for instance), when the SD card is removed from the computer without being ejected, or when the files on the SD are manipulated (such as rotating it) on the computer and then returning the card to the camera.
Even though the camera may not be able to read or display these files, I have found that sometimes the computer is still able to. Before giving up on all the images, try them in a computer both via one or more card readers or directly in an SD card slot.
If all else fails, you can reuse the SD card by formatting it in the camera.
Jul 29, 2013 | Pentax K20D Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
Pentax K100D. PC has stopped recognising the camera when connected via USB in PC or PC-F setting. Problem on 2 different pc's
This is seriously easy. Do not connect the camera to the computer.
Buy yourself a card reader from maplin, plug thaqt into the computer and then take the SD ard from the camera and put it into the card reader. The card will then be seen by the computer as a mass storage device and you can do what you wish with the images after that.
I haven't connected any of my digital cameras to any of my computers for about 5 years now.
Apr 21, 2011 | Pentax K100D Digital Camera
Describe your can pentax s5z 4 gb Problem
Did you format the card in the camera before using it?
Feb 10, 2010 | Pentax Optio S5z Digital Camera
What is the largest capacity SD card that I can use with a Pentax IST ds camera?
The camera uses SD memory cards. SD cards max out at 2GB. SDHC cards run from 4GB up, but they cannot be used in SD devices. SD cards can be used in SDHC devices.
The short answer is 2GB.
Jan 11, 2010 | Pentax *ist DS Digital Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
Software Installation
Pentax camera creates an own folder at each inserted SD card. So, try to find your image and video files in the folder named 100PENTX. For example, my camera saves the shot images into folder: SD card:\DCIM\100PENTX.
Sep 08, 2005 | Pentax Optio SV Digital Camera
Pentax *ist DS Digital Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
